FME Transformers: 2025.1 BETA
Categories
Rasters
Related Transformers
PointCloudOnRasterComponentSetter
PointOnRasterValueExtractor
RasterAspectCalculator
RasterBandInterpretationCoercer
RasterBandKeeper
RasterBandNameSetter
RasterBandNodataRemover
RasterBandNodataSetter
RasterBandRemover
RasterCellCoercer
RasterCellValueCalculator
RasterCellValueReplacer
RasterCellValueRounder
RasterConvolver
RasterHillshader
RasterMosaicker
RasterPaletteAdder
RasterPaletteExtractor
RasterPaletteGenerator
RasterPaletteInterpretationCoercer
RasterPaletteNodataSetter
RasterPaletteRemover
RasterPaletteResolver
RasterSingularCellValueCalculator
RasterSlopeCalculator
RasterToPolygonCoercer
Scaler
VectorOnRasterOverlayer
RasterSelector
Selects specific bands and palettes of a raster for subsequent transformer operations.
Jump to Configuration
  • Isolating specific bands or palettes to perform operations on.
The RasterSelector receives raster features and designates specific bands and palettes as “selected.”
Once a selection is performed, transformers that support raster selection will only affect the selected bands and palettes. Unselected elements are passed through unaltered, and remain in an unselected state until another RasterSelector operation is performed.
The default state of a raster feature is that all bands and palettes are selected - that is, after reading in the raster, subsequent raster transformers will operate on all bands and palettes. Raster transformers may support both band and palette selection, band selection only, or may be unaffected by it. Check a transformer’s documentation for raster selection support details.
Bands and palettes are selected using the band and palette indices, specified in a string. The string may either be entered as a parameter or provided as an attribute.
Selection Strings
The format of the string is B:P (band number, then palette number, separated by a colon). If the raster does not have palettes, only band numbers should be specified.
  • Indices are zero-based, so the first band or palette is at index 0.
  • The keyword ALL can be used in place of band and palette numbers to select all bands or all palettes on a specific band.
  • Multiple bands or band-palette pairs are separated by a semicolon (;).
  • Multiple palettes on one band are separated by a comma (,).
Selection String Examples
All bands
ALL:
All bands and all palettes
ALL:ALL
First palette of the first band of a raster
0:0
First palette of the first band and first palette of the third band
0:0;2:0
First three bands of the raster (without palettes)
0:;1:;2:
First three bands of the raster (with their palettes)
0:ALL;1:ALL;2:ALL
First two palettes on the first band
0:0,1
  • It is possible to select bands without selecting the attached palettes.
  • It is NOT possible to select palettes without selecting the owning band.
  • Specific palettes cannot be selected on ALL bands; for example, ALL:2.
Selection String Syntax Change
As of FME 2021.2, the syntax used for band and palette selection strings is as documented above. Selection strings created with the previous format (as in previously-saved workspaces) are converted automatically.
  • This function overrides any existing selection on the raster. All unspecified bands and palettes on a raster after selection are treated as unselected for future operations.
  • Selection is not considered by writers, so use the RasterBandSeparator and filtering to write subsets of the bands and palettes as individual features.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases RasterBandSelector, RasterPaletteSelector
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the RasterSelector on the FME Community.
