FME Transformers: 2025.1 BETA
Categories
Rasters
Related Transformers
AttributeFileWriter
RasterPaletteAdder
RasterPaletteGenerator
RasterPaletteRemover
RasterPaletteResolver
RasterPaletteExtractor
Creates a string representation of an existing palette on a raster and saves it to an attribute.
Jump to Configuration
  • Extracting a palette to be saved to an external file
  • Extracting a palette to apply to other rasters or for use elsewhere in a workspace
The RasterPaletteExtractor receives raster features and copies the palette information to a string attribute. Only one palette may be extracted at a time.
This transformer supports raster band and palette selection. Exactly one palette must be selected on each input raster feature. The RasterSelector can be used to modify selection.
This transformer may be used in combination with the AttributeFileWriter to write a palette to a file.
Format of Palette Attributes
The general format of a palette attribute is as follows:
Format
RGB Example
String Example
<value interpretation> [<string length>]
<key 0> <value 0>
<key 1> <value 1>
<key n> <value n>
RGB24
0 0,49,190
1 50,255,50
2 172,0,255
3 255,0,0
STRING 10
0 Water
1 Forest
2 Commercial
3 Urban
The first line of the palette must contain the value interpretation. Valid values for the value interpretation are:
  • RGB24
  • RGBA32
  • RGB48
  • RGBA64
  • GRAY8
  • GRAY16
  • STRING
RGBA and RGB palette values consist of comma-delimited strings of integers between 0 and the maximum value of the data type. For example, a valid RGBA32 value would be 64,128,255,255, and a valid RGB48 value would be 16384,32768,65535.
When an interpretation of STRING is specified, the first line may optionally specify the maximum string length of the palette values. This value must be a positive integer. If no string length is explicitly specified, a default of 32 will be assumed.
STRING palette values may consist of any arbitrary text, except for the newline character.
GRAY palette values consist of a single integer between 0 and the maximum value of the data type.
All lines after the first are key-value pairs. Palette keys must be organized in ascending order, but they are not required to be contiguous - that is, not all numbers in the series must be present. All absent palette keys look up to 0 or an equivalent value, such as 0,0,0 for RGB or an empty string for string palettes.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the RasterPaletteExtractor on the FME Community.
