FME Transformers: 2025.1 BETA
Categories
Calculated Values
Rasters
Related Transformers
RasterBandMinMaxExtractor
RasterPropertyExtractor
RasterStatisticsCalculator
RasterBandPropertyExtractor
Extracts the band and palette properties of a raster feature and adds them to a list attribute.
Jump to Configuration
  • Extracting band and palette information from raster features
The RasterBandPropertyExtractor receives raster features, and extracts any existing band and palette properties. The results are added to a new list attribute (because a raster may have multiple bands), and output with the original feature.
The transformer has no parameters.
Property attributes include:
_band{}.band_name
_band{}.band_interpretation
_band{}.band_bit_depth
_band{}.band_interleaving
_band{}.band_num_tile_rows
_band{}.band_num_tile_columns
_band{}.band_nodata
_band{}.band_num_palettes
_band{}.palette{}.palette_name
_band{}.palette{}.palette_key_interpretation
_band{}.palette{}.palette_value_interpretation
_band{}.palette{}.palette_bit_depth
Wherever "{}" appears, there will be one instance of the attribute for each band or palette. The first will appear with {0}, the second with {1}, and so on.
If a raster band has no palettes, _band{}.band_num_palettes will be zero (0), and no further palette attributes will be added.
Choosing a Raster Transformer
Note  Feature order may change in relation to other output ports. Feature order per port is maintained.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases RasterBandPropertiesExtractor
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the RasterBandPropertyExtractor on the FME Community.
