FME Transformers: 2025.1 BETA
Categories
Rasters
Related Transformers
RasterPaletteAdder
RasterPaletteExtractor
RasterPaletteResolver
RasterPaletteGenerator
Generates a palette from the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette.
Jump to Configuration
  • Creating a palette based on raster contents for use elsewhere.
  • Reducing file size or bit depth on rasters to meet format or processing requirements.
The RasterPaletteGenerator receives raster features and builds a palette from the existing cell values. The output raster feature will have the selected band(s) replaced with a band with the resulting palette, and cell values replaced with palette key values.
The Palette Key Interpretation Type may be UInt8, UInt16, or UInt32, and both the new palette and band will have the chosen interpretation type. The number of palette keys generated can be automatically determined, or specified within the range of 16 to the maximum number of values supported by the interpretation type.
Key Value Range
Minimum Number of Keys
Maximum Number of Keys
UInt8 0 to 255 16 256
UInt16 0 to 65,535 16 65,536
UInt32 0 to 4,294,967,295 16 4,294,967,296
Valid palette types that may be produced include:
  • RGB24
  • RGB48
  • RGBA32
  • RGBA64
  • GRAY8
  • GRAY16
This operation may cause loss of precision if the maximum number of palette entries is less than the number of unique band values. In this case, the data values in the palette may not capture all the original band data values.
This transformer supports raster band selection. The RasterSelector can be used to modify selection.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the RasterPaletteGenerator on the FME Community.
