FME Transformers: 2025.1 BETA
Categories
Coordinates
Rasters
Related Transformers
CoordinateSystemSetter
RasterGCPExtractor
RasterGCPSetter
Reprojector
RasterGeoreferencer
Georeferences a raster by either known corner coordinates or origin, cell size, and rotation.
Jump to Configuration
  • Adding known position information to rasters.
  • Georeferencing rasters with non-spatial content for cartographic purposes.
The RasterGeoreferencer receives raster features and tags them with georeferencing information as provided in the various parameters.
There are two methods of georeferencing available:
Point and Angle
Georeferences based on the known origin (upper left corner) coordinates, cell spacing (cell size), and rotation.
Extents
Georeferences based on the coordinates of all four corners of the raster, which must form a rectangle.
A CoordinateSystemSetter may be used in conjunction with a RasterGeoreferencer to provide complete position information.
If the raster is already georeferenced, the existing georeferencing information will be overwritten.
  • Georeferencing does not alter cell values or require interpolation - it only tags the raster with positional information to be interpreted by a product. It differs from reprojection, where the raster itself is transformed from one known coordinate system to another, interpolating new cell values. A Reprojector may be used for this.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the RasterGeoreferencer on the FME Community.
