FME Transformers: 2025.1 BETA
Categories
Rasters
Related Transformers
RasterBandInterpretationCoercer
RasterInterpretationCoercer
RasterPaletteInterpretationCoercer
Alters the interpretation type of raster palettes.
Jump to Configuration
  • Adding or removing alpha (transparency) values on color palettes
  • Altering palette interpretation type to meet format or processing requirements
The RasterPaletteInterpretationCoercer receives raster features and alters the interpretation type of selected palettes, adjusting palette values if necessary.
Palettes may be converted to:
  • RGB24
  • RGBA32
  • RGB48
  • RGBA64
  • GRAY8
  • GRAY16
  • STRING
A variety of options are available, depending on the Destination Interpretation Type, to specify how value conversions are handled when:
  • Adding or dropping alpha values
  • Converting colors to a different type (casting and scaling)
  • Converting decimal values to integers
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the RasterPaletteInterpretationCoercer on the FME Community.
