FME Transformers: 2025.1 BETA
Categories
3D
3D
Rasters
Related Transformers
RasterAspectCalculator
RasterHillshader
Scaler
RasterSlopeCalculator
Calculates the slope (maximum rate of change in z) for each cell of a raster.
Jump to Configuration
  • Calculating slope on elevation rasters
  • Calculating the rate of change on raster band values
The RasterSlopeCalculator receives raster features, and calculates the slope for each cell.
Slope may be measured in either Degrees (0 to 90), or Percent Rise (0 to infinity). The calculation is done based on the values of surrounding cells (using a 3 cell x 3 cell window), and a choice of algorithms is available. Cells without data (Nodata) may be interpolated for calculation purposes.
Slope values are output on the same band they were calculated from, and the band is converted to Real64.
For multi-band rasters, each band is processed separately, with slope values calculated for each band on each cell. To restrict operation to specific band(s), use a RasterSelector prior to the RasterSlopeCalculator.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
Z Factor, Scaling and Units
Input rasters’ horizontal (x and y) units are expected to be the same as vertical (z) units.
If this is not the case - for example, if the horizontal units are in meters with elevation (z) in feet (or any other similar unit type mismatch), you may apply a scale factor (also known as Z Factor) with the Scaler transformer prior to using a RasterSlopeCalculator.
In this example (ground units are meters, elevations are feet), the scale factor to use is 0.3048 - the number of meters in one foot.
If the ground units are lat/long, the appropriate scale factor will vary greatly between the equator and the poles. In this case, consider reprojecting the input raster with a Reprojector, to an appropriate coordinate system with ground units matching the vertical (z) units.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the RasterSlopeCalculator on the FME Community.
