FME Transformers: 2025.1 BETA
Categories
3D
3D
Coordinates
Geometries
Related Transformers
3DAffiner
Affiner
AffineWarper
ExpressionEvaluator
Offsetter
PointCloudExpressionEvaluator
RasterExpressionEvaluator
RasterGeoreferencer
Rotator
Scaler
Scales x, y, and/or z coordinate values to resize geometry.
Jump to Configuration
  • Scaling z values for emphasis or de-emphasis
  • Scaling z values when vertical and horizontal units are mismatched
  • Georeferencing
  • Sizing objects or labels
  • Mirroring objects
  • Changing units
The Scaler receives features with any type of geometry and applies a multiplier to their coordinates, resizing the features relative to either their center or the origin of their coordinate system.
X, y and/or z coordinates are multiplied by the provided X, Y, and Z Scale Factors. A scale factor of one (1) implies no change to a coordinate.
The origin for scaling may be either 0,0 in the feature’s own coordinate system, or the center of the feature itself.
When using the 0,0 origin, if the object being scaled is not on or near the 0,0 point of the coordinate system (as is usually the case with georeferenced data), using the Scaler will also introduce a shift.
When using the Center Point origin, each individual feature will be scaled around its own center, not the center of the dataset’s extents.
Additional parameters are provided for type-specific scaling, including text, raster, and point cloud. This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the Scaler on the FME Community.
