FME Transformers: 2025.1 BETA
MapnikRasterizer
Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit.
- Creating cartographic renderings of vector features or vector on raster features
The MapnikRasterizer provides an interface to the Mapnik toolkit. It receives vector and/or raster input features and renders them as a raster image using cartographic styles based on the parameters selections.
When placed in the workspace, a MapnikRasterizer has one input port, Connect Input. Features may be connected to this port, which creates a new input port for each item connected there. Multiple feature input feature streams may be connected to one input port, if they are to receive the same styling, and are the same geometry type - for example, connecting several types of roads to a single Roads port.
The parameters dialog contains a table of Rendering Rules. Each Rule is composed of an Input Port, a Symbolizer, and Style. Multiple Rules may be created for one input port - for example, a Boundaries layer might be entered three times - once to style the lines, again to add a glow behind them, and again to create and style labels from an attribute.
A variety of Symbolizers are available, including line, point, and polygon styles and patterning, text, shields, and point markers, as well as rasters. Each type has associated style choices. For many styling options, conditional values are permitted, where a table of test conditions may be created to assign varying values - colors or line widths, for example.
Layers will be drawn in the order they appear in the Rendering Rules table - that is, the first item will be drawn first (at the bottom of the image), and subsequent items rendered over top of previous items. Ordering will determine how objects that overlap will appear - later items may cover earlier items.
Note Full symbolization details are available in the Mapnik documentation.
Output rasters may be sized by defining their dimensions (number of columns and rows) or by specifying pixel size in ground units (horizontally and vertically). The ground extents covered by the raster default to the extent of all the input features, but can be specified. If specified extents are smaller than the extent of the data, it will be clipped to the defined area.
Raster Interpretation Type may be either RGB24 or RGBA32 (with alpha). The background of the raster can be either a specified color, or an image to be tiled over the extent of the raster. To use a georeferenced raster as the entire background, it should be connected to an input port and styled using the Rendering Rules and a Raster symbolizer (not attached as the Background Image).
In this example, we will create a raster representation using a number of datasets. The source data includes:
- An orthophoto (GeoTIFF)
- Parks (polygons)
- Bike paths (lines with attributes to be used for labeling)
- Three (3) separate street food vendor datasets (points)
All source datasets are routed into a MapnikRasterizer. creating new input ports when required by connecting to the Connect Input port. Note that all three of the food vendor datasets are connected to the same port - they are all point geometry, and will all be styled the same way.
In the parameters dialog, we set the output raster size to be based on one (1) meter pixels (cells), and construct the Rendering Rules table.
Note the following choices:
GEOTIFF (the orthophoto) goes first, to provide a background for the output raster. It is styled with a Raster symbolizer. Opacity is set to .7, to fade the image a bit and allow the rest of the features stand out. |
Parks are next, styled with a Polygon symbolizer. They are filled green, and Opacity set to .5. If we wanted to draw a contrasting border around the parks, we would duplicate the rule, and use a Line symbolizer to style the border. |
Bike_ALL contains the bike paths, with attributes. We have created two rules for them (using the copy and paste tools below the table) - note that they do not appear together in the table, and are separated by the FoodVendors layer. The first rule styles the lines, and the second performs labeling. Food vendor symbols may overlap the lines, but will appear behind any bike path labels they may collide with. To generate the labels, we select the PathName attribute. The Halo Fill parameter produces a glow behind the letters, making them more visible against the background and other features. |
Line styling:
Labeling:
FoodVendors contains all three of the point datasets attached to this input port. Renaming a port in the Rendering Rules table is reflected in the transformer itself - this port was created when Hot Dogs was attached to Connect Input, and then renamed in here. This layer is styled with a Point symbolizer. By choosing Symbol Type, Image, we can select a symbol raster to be used - in this case, an orange marker that has been saved as a PNG file with a transparent background. The symbol was scaled to the appropriate size by using the Transform parameter, scale(.25). |
![]() OrangeMarker.png has a transparent background:
Full documentation of all styling parameter choices and behavior can be found in the Mapnik documentation.
The raster is produced according to the parameter selections.
Choosing a Raster Transformer
Working with Rasters
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Input ports are created by either connecting a feature stream to the Connect Input port, or by adding them in the Rendering Rules table, Input Port column.
Input ports may also be renamed, moved, and deleted in the Rendering Rules table.
The raster(s) drawn from a group of features according to the parameter selections.
Invalid features that will not be included in the output raster.
Group By |
If the Group By parameter is set to an attribute list, one raster per group will be produced. |
Complete Groups |
![]() There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order.
This table defines the layers and symbolizers that specify how features will be rendered.
Each entry in the table contains an input port, a symbolizer type, and the parameters for that symbolizer. The symbolizer parameters depend on the symbolizer type. Descriptions of the parameters for each symbolizer may be found in the Mapnik documentation.
Note that layers will be rendered in the order they are specified. The first layer in this table will be rendered first (that is, it will appear below any subsequent layers).
Rules may be duplicated to add additional styling.
Input Port |
The name of the layer, also reflected in the transformer in the workspace. Multiple feature streams may be connected to a single input port, should be the same geometry type, and will have identical styling. |
Symbolizer |
Select a type of styling to be done to the features. Options include:
Style |
Edit… will open a parameters dialog specific to the Symbolizer type. |
Layer Definition
This parameter specifies what defines a layer.
Each rendering rule is a layer |
Each individual rule in the above table will be rendered as a separate layer. |
Each input port is a layer |
Each input port will be rendered as a layer. Note that some layers will contain multiple symbolizers in this case. |
Essentially, this determines the draw order of the rendering rules. Layers are rendered in order, with all features for a layer drawn before any features of the next layer. Within a layer, symbolizers are applied feature-by-feature.
Example: You have line features representing streets, and each feature also contains an attribute specifying the street name. To render this, you could set up a Line symbolizer and a Text symbolizer. In this case, you would want to draw all the streets first, then have all the labels on top of those, so Each rendering rule is a layer would be more appropriate.
Example: You have overlapping polygons, and want to draw each with a border. To render this, you could set up a Polygon symbolizer and a Line symbolizer. In this case, you would want to draw each feature as both a polygon and a line before moving on to the next feature, so Each input port is a layer would be more appropriate.
Note that the behavior of Each rendering rule is a layer can be replicated when Layer Definition is set to Each input port is a layer. To do this, just add a new input port for each separate layer.
Resolution Specification |
Select a method of defining output raster size:
Number of Columns (cells) |
If Resolution Specification is Columns and Rows, enter the width of the output raster in cells (pixels). |
Number of Rows (cells) |
If Resolution Specification is Columns and Rows, enter the height of the output raster in cells (pixels). |
Cell Spacing |
If Resolution Specification is Cell Spacing, enter the width of the output raster cells, measured in ground units. |
Interpretation Type |
Set the output raster’s Interpretation Type. Options include:
The background may be filled with a solid color and/or image. If neither a color nor image is specified, the background will be transparent.
Color |
Sets the background color. Specifying Colors Colors may be entered directly or chosen from the color picker via the ellipsis button. ![]() Colors can be specified by RGB values or hex codes. RGB values may be either 24-bit or decimal (0 - 1). In the case of (1,1,1) which is valid for both 24-bit and decimal, the decimal interpretation (white) is generally used when specifying colors*. Hex codes are accepted with or without a hash sign (#).
* Color interpretation may vary in other contexts such as raster bands and palettes. |
Color Alpha Value (0-1) |
Sets the alpha value for the background color. It must be a number between 0 and 1, where 0 is fully transparent and 1 is fully opaque. |
Image |
Select an image file to be used as the background. If the image is smaller than the extent of the output raster, it will be tiled. Georeferencing will not be honored for background images - to use a georeferenced raster, connect it to an input port and use the Rendering Rules table. |
Ground Extents |
If Use input data ground extents, the extents are not explicitly specified, and the output raster extents will be determined by the union of the bounding boxes of the valid input vector features. If Specify ground extents, the remaining Ground Extents parameters are used to specify the extents of the output raster. The output raster will be clipped to the specified extents. |
Minimum X |
This specifies the minimum x value of the output raster. It is used when the Ground Extents parameter is set to Specify ground extents. |
Minimum Y |
This specifies the minimum y value of the output raster. It is used when the Ground Extents parameter is set to Specify ground extents. |
Maximum X |
This specifies the maximum x value of the output raster. It is used when the Ground Extents parameter is set to Specify ground extents. |
Maximum Y |
This specifies the maximum y value of the output raster. It is used when the Ground Extents parameter is set to Specify ground extents. |
Yes |
Dependencies | None |
Aliases | |
History |
Search for all results about the MapnikRasterizer on the FME Community.
