FME Transformers: 2025.1
AttributeFileWriter
Writes the contents of an attribute to a text or binary file.
- Writing files mid-workspace that contain the value of an attribute
- Replacing a writer where the desired content is stored as an attribute
- Writing images that have been stored as blob attributes
- Writing coordinate system information to a file
- Writing text lists of attribute values
The AttributeFileWriter receives any type of feature and writes the contents (value) of a specified attribute to an external file.
A Target Filename and encoding type must be specified. File names may be provided explicitly or by attribute value, expression, user parameter, or conditional value. If a target file already exists, it may be overwritten or appended to.
The attribute value and target file may be text or binary. A variety of encoding choices are available for text files. Binary files should be designated as Binary (fme-binary), as the transformer writes it as-is and will simply preserve the attribute contents as a Blob.
In this example, we have a shape file of city parks. Some of them are dog parks, and we want to write a text file containing all of their names.
Note that the source data has a number of attributes, including DogPark and ParkName.
This will take three steps:
- Use a Tester to identify only the dog parks.
- Add a carriage return to the park name with an AttributeManager.
- Write a text file with the AttributeFileWriter.
In the parameters dialog of the Tester, we create one Test Clause, looking for DogPark = Y.
Next, we need to add a carriage return to the end of the attribute so that each one will be written on a separate line.
In the parameters dialog of an AttributeManager, we use the Text Editor to construct an expression that will add the special character to the existing ParkName attribute value.
The final step is to write the text file. In the parameters dialog of the AttributeFileWriter, we choose the ParkName attribute and set a Target Filename.
If Target File Exists is set to Append to file, and a text encoding is chosen.
The output file, as examined here in Notepad, contains the dog park names.
A variation on this would be to add <p> tags around each line, with a <br> tag line break, to write the output as very basic HTML.
- When writing any binary file types, ensure that Target File Encoding is set to Binary (fme-binary).
- Full path names can be created from existing attribute values by using the Text Editor to create an expression.
- The most common text encodings are Windows Latin-1 (windows-1252) and Unicode 8-bit (utf-8).
- If you are unsure of the encoding used by the attribute, the Feature Information window in the FME Data Inspector will often help.
Features with attributes to be written to files.
Unmodified features. Files will have been written as specified in the parameters.
If an invalid filename is specified, the feature will be routed to the <Rejected> port. Rejected features will have an fme_rejection_code attribute with one of the following values:
INVALID_FILE_INACCESSIBLE
Source Attribute |
Name of the attribute whose value will be written out to a file. |
Target Filename |
The name and location of the file to be written. It may be specified explicitly or by attribute value, expression, user parameter, or conditional value. |
If Target File Exists |
Specifies the action to take if the target file already exists.
Note that when appending to a text file, you may want to add a special character (newline or carriage return) to the attribute value prior to the AttributeFileWriter. |
Target File Character Encoding |
The character encoding of the target file. The default encoding is System default (fme-default). Note that binary files must be specified as Binary (fme-binary) regardless of type. |
Dependencies | None |
Aliases | |
History |
Search for all results about the AttributeFileWriter on the FME Community.
