FME Transformers: 2025.1 BETA
Tester
Evaluates one or more tests on a feature, and routes the feature according to the outcome of the test(s).
- Performing quality testing on data
- Dividing features into two streams based on a test
- Isolating a subset of features based on a test
The Tester accepts any feature. It evaluates each feature against one or more user-defined tests, and outputs the feature via the Passed port if it meets the defined conditions, or via the Failed port if it fails the defined conditions.
The tests are constructed as a series of Test Clauses, which evaluate values or expressions based on a wide range of available Operators and test types. The Test Clauses are connected with Logic - combinations of AND, OR, and NOT, with parentheses to define evaluation order.
Creating Test Clauses
Each clause is composed of a value to test, and the method of testing it. Depending on the type of test, at a minimum the clause will consist of a Left Value and an Operator. If the chosen Operator needs more information (for example, testing for an attribute that is greater than a certain value), a Right Value field is provided.
The Test Clauses are created in a table, and numbered from the top down.
Left Value |
Operator |
Right Value |
Mode* |
The value or expression to test | The type of test to perform | The value for comparison, if required by the operator | Test the values in a specific manner |
Examples | |||
Latitude | > | 49.000001 | Automatic |
@Area() | In Range | (1,100) | Numeric |
SnackType | Like | Kebabs | Case Sensitive |
Traffic | Attribute Is Null | <Unused> | Automatic |
Count | Type Is | Integer | Automatic |
* Note that Mode is only available for individual tests when Comparison Mode is set to Specify Per Test.
Test Clause Operators
These are the Operators available for constructing test clauses. They may be used to test attribute values, constructed expressions, constants, and published parameters.
Note that (unless otherwise specified) most operators can be used with both numeric values and strings. Strings may be compared with the =, !=, <, >, <=, and >= operators, and are evaluated by their character codes, so A < B.
Operator |
Description |
Right Value Configuration |
= | Equal to | Enter a value for comparison. | ||||||||||||||||
!= | Not Equal to | Enter a value for comparison. | ||||||||||||||||
< | Less than | Enter a value for comparison. | ||||||||||||||||
> | Greater than | Enter a value for comparison. | ||||||||||||||||
<= | Less than or equal to | Enter a value for comparison. | ||||||||||||||||
>= | Greater than or equal to | Enter a value for comparison. | ||||||||||||||||
In Range |
Tests if the value falls within the numeric range specified in set notation. Open-ended ranges may be defined by leaving either the lower or upper limit blank. |
Range values are separated by a comma and enclosed by brackets. Square brackets - [ ] - indicate inclusive limits (greater than or equal to, less than or equal to). Round brackets - ( ) - indicate exclusive limits (greater than, less than). Valid range examples: (1,9) Greater than 1 and less than 9 [1,9] Greater than or equal to 1 and less than or equal to 9 (1,9] Greater than 1 and less than or equal to 9 (1,) Greater than 1 [,9] Less than or equal to 9 Note This operator is not available when Mode is set to Case Sensitive or Case Insensitive, and those modes are not available when the operator is set to In Range.
In | Tests if the value may be found in the provided list of possible values and ranges. |
Enter any combination of comma-separated strings, numeric values, and/or ranges (in the form of x-y). Valid configuration examples: 1,10,100 1-99 cat cat,dog,cats and dogs dogs,1-9,7 String ranges (for example, a-d) can also be specified. To test for values that contain a hyphen, enclose the value in quotation marks: "LL-27","LL-83". To test for values that contain either single (') or double (") quotes, enclose the value in the opposing quotes: "Duncan's Lake" or 'Say "Hello"'. |
Like | Tests that the value matches a specified string pattern. |
Enter a string pattern. Wildcards are supported using the percentage symbol (%), rather than an asterisk (*). In Automatic mode, this operator is case insensitive. This operator is not available when Mode is set to Numeric. Example: If Right Value is %bc%: abcd: Passed bc: Failed |
Contains | Tests that the Right Value occurs somewhere in the Left Value. |
Enter a value to test for. In Automatic mode, this operator is case insensitive. This operator is not available in Numeric mode. Example: If Right Value is bc: abcd: Passed abde: Failed |
Begins With | Tests that the Left Value string begins with the Right Value string. |
Enter the string to be tested against. In Automatic mode, this operator is case insensitive. This operator is not available in Numeric mode. Example: If Right Value is Do: Dogs: Passed Cats: Failed |
Ends With | Tests that the Left Value string ends with the Right Value string. |
Enter the string to be tested against. In Automatic mode, this operator is case insensitive. This operator is not available in Numeric mode. Example: If Right Value is gs: Dogs: Passed Cats: Failed |
Contains Regex | Tests that the value contains a string that matches a pattern described by a Regular Expression. |
Enter a Regular Expression. The Regular Expression Editor is available via the ellipsis (...) button, and may be used to construct and test expressions. The regex to test may represent a string to be found anywhere within the value, or may represent the entire value (by creating a regex long enough to represent the extent of the desired value). Example: If regex is \d (Any digit) cats: Failed 9: Passed cats82: Passed |
Type Is |
Tests if the value is compatible with the chosen Type. You may test for multiple types by adding additional Test Clauses. |
Select the Type to test for.
Encodable In | Tests if the value is encodable in the specified encoding without data loss. |
Select from a list of standard encodings. Sample encodings:
Attribute has a value | Tests that the attribute has a value, and is not null, missing, or empty. | <Unused> | ||||||||||||||||
Attribute Is Null | Tests that the attribute has a null value. |
<Unused> |
Attribute is Empty String | Tests that the value is an empty string. | <Unused> | ||||||||||||||||
Attribute is Missing | Tests that the attribute is absent on the feature | <Unused> |
Cached Values and Data-Aware Test Clauses
If Feature Caching is enabled, valid attribute values from upstream features can be viewed to complete test clauses.
As shown here in the Tester, if the Left Value has been set to an Attribute Value and the features have been cached, the context menu provides access to the values available in those features. If there are only a few choices, they will be presented in a sub-menu.
If there are a large number of choices, the values will be presented in a Select Value dialog, where the values may be sorted and searched with the Filter option.
Connecting Test Clauses: Logic
Multiple test clauses are connected with Logic, using AND, OR, and NOT in addition to parentheses to specify how the tests are evaluated to determine passing or failing.
Logic connectors can be edited by selecting options in the Logic column of the Test Clauses table, or may be edited directly using the Composite Expression parameter’s Edit button.
In this example, we start with a dataset of food trucks, and want to identify any records that are missing a Business Name.
The features are routed into a Tester.
In the parameters dialog, we configure one test. The Left Value is set to the BUSINESS_NAME attribute, and the Operator is set to Attribute has a value.
As there is only one test, the Pass Criteria (AND/OR/Composite) is not relevant.
No Right Value is required, as the test is simply looking for the existence of any value.
Features that fail the test are output via the Failed port, and can be sent for further processing elsewhere.
In this example, we start with a dataset of food trucks, and wish to test for those that are serving Mexican food. The features are routed into a Tester.
In the parameters dialog, we construct two tests, both using the DESCRIPTION attribute as the Left Value.
The first test looks for an exact match - any feature where the DESCRIPTION is Mexican Cuisine. The second test is less strict - it looks for any values that begin with Tacos.
The Logic connector is OR - meaning any feature that matches either of these tests will be output via the Passed port.
Comparison Mode is set to Case Insensitive, which will apply to both test clauses.
Four features match at least one of the tests.
In this example, we start with a dataset of city parks. We will test them to find dog parks of a certain minimum size, in two specific neighborhoods. The features are routed into a Tester.
In the parameters dialog, we add four individual test clauses:
- Dog Park: Y
- Area is greater than 40000 ( square meters, in ground units - using the @Area() function to evaluate the geometry)
- Neighborhood Name is Strathcona
- Neighborhood Name is Fairview
As we have two choices of neighborhood name, we use a Composite Expression to describe the test conditions we want:
- 1 AND 2 AND (3 OR 4) means (note that the numbers indicate the row number of the test clause):
- It must be a dog park (rule 1), AND;
- It must be greater than 40,000 m2 (rule 2), AND;
- It must be in either the Strathcona (rule 3) OR Fairview (rule 4) neighborhood.
The Logic connectors and parentheses can be selected in the Logic column, or entered directly using the Edit button.
Two parks meet the criteria.
- Due to bulk mode processing, features may appear to output in chunks. Although feature order from a single output port remains intact, when chunks of features are output through both the Passed and Failed ports, unexpected results may occur in workspaces that rely on feature ordering from joined output ports. In these scenarios, we recommend that you do not upgrade the Tester to its 2019.1 or later version, or revise your workspaces so they do not rely on feature ordering from joined output ports. Feature ordering may be specified with the Advanced > Preserve Feature Order parameter.
- If you have several Tester transformers in sequence, consider using the TestFilter instead. This transformer allows you to create a series of tests with named output ports for each result.
- Note that testing operations are lexical comparisons and not locale-aware.
- When filtering out a subset of features, consider the logic of the test(s) when choosing an output port. For example, to remove all of the Dog Parks from a list of parks, you could either:
- Set DogParks=Y, and connect the Failed port (dropping the Passed features), or
- Set DogParks=N, and connect the Passed port (dropping the Failed features).
Features to be tested.
If the feature passes according to the test configuration, it is output via the Passed port.
If the feature fails according to the test configuration, the feature is output via the Failed port.
See Creating Test Clauses above for further detail.
Logic |
Determines how clauses are evaluated in a composite test. Note that changes made using the Composite Expression parameter’s Edit function will be reflected in this column once they have been Applied, including the placement of parentheses.
Left Value |
The Left Value may be the value of an attribute, expression, a literal constant, a published parameter or a calculated value that is a combination of the above. If it is a calculated function or expression, it will be executed for each feature and the result will be used for the test. |
Operator |
Select the type of test to be performed. Options include:
Right Value |
Enter any required comparison values or supplementary configuration information for the test selected. Depending on the Operator chosen, a drop-down list of choices or an ellipses button accessing an additional dialog with correct parameters may become available, to assist in entering values. |
Mode |
If required, specify a method for evaluating values. This column is only available when Comparison Mode is set to Specify Per Test. See Comparison Mode below for available options. |
Comparison Mode |
Specify a method for evaluating values. This choice will be applied to all tests, unless Specify Per Test is selected, enabling the Mode column in the Test Clauses table.
Tip If you know your data is string data, you should set the mode to either Case Sensitive or Case Insensitive. This way, FME does not spend time for each feature to determine if the data is representable as a number, but can just do the string comparison immediately.
Composite Expression |
Enabled when multiple test clauses are created. Enter or edit a test expression that defines the criteria to met in order for a feature to be considered Passed. If edits are made here, the changes will be reflected in the Test Clauses table’s Logic column once the Apply button is used to save changes. Inversely, changes made by selecting Logic options will be reflected here. Test Clauses are referred to by their number, in the order listed in the Test Clauses table. Clauses may be joined by AND, OR, and NOT, with parentheses. Example: ((1 AND 2) OR 3) Interpretation: Clause 1 AND Clause 2 must be true, OR Clause 3 must be true. See the Composite example above for a use case. |
When doing comparisons, null, missing, and empty string values, all evaluate to empty string. Thus, they are considered equal in the context of the comparison operators. Further, the following comparison ordering is respected:
- Null, missing, empty string < other values
In Automatic mode, all operators are case sensitive except Like, Contains, Begins With, and Ends With.
Preserve Feature Order |
Dependencies | None |
Aliases | |
History |
Search for all results about the Tester on the FME Community.
