FME Transformers: 2025.1 BETA
Labeler
- Annotating linear features
The Labeler receives linear features and generates text labels at intervals along them. Labels are rotated to match the orientation of the segment being labeled, with various size and position parameters.
Collision avoidance and minimum feature length for labeling are both available.
Label Orientation
The orientation of the text varies according to the orientation of the line segment it is placed on. Text is placed parallel to the line segment.
If the line angle produces text that is upside-down (that is, between 90 and 270 degrees), the text is rotated 180 degrees.
Both the line and text angles may be added as an output attribute.
Label Placement Interval and Starting Position
Label intervals are determined by the Label Spacing and Labels at End Points parameters.
If Label Spacing is zero (0), only one label is placed.
This input feature will be labeled with a Label Height of 8. It is 100 meters long.
Action |
Parameters |
Result |
Place one label at the start of the feature. |
Label Spacing: 0 Labels at End Points: Yes |
Place one label at the midpoint of the feature. |
Label Spacing: 0 Labels at End Points: No |
Place labels every 40 meters, and at the first and last points of the feature. |
Label Spacing: 40 Labels at End Points: Yes |
Place labels every 40 meters, but not at the end points.
Label Spacing: 40 Labels at End Points: No |
Label Positioning
When an offset is applied to labels, the Label Position parameter determines where label insertion points are placed relative to the feature.
Note that left and right are relative to direction of travel along the feature - they are not the left- and right-hand side of the field of view.
This input feature will be labeled. Note its orientation, indicated by the arrow.
The labels are placed with a large Label Offset value to illustrate position.
Label Position |
Placement |
Result |
Above or Left |
Label insertion points are placed above the feature. Where a line segment is vertical, labels are placed to the left, relative to the feature orientation. |
Above or Right |
Label insertion points are placed above the feature. Where a line segment is vertical, labels are placed to the right, relative to the feature orientation. |
Below or Left |
Label insertion points are placed below the feature. Where a line segment is vertical, labels are placed to the left, relative to the feature orientation. |
Below or Right |
Label insertion points are placed below the feature. Where a line segment is vertical, labels are placed to the right, relative to the feature orientation. |
Left |
All label insertion points are placed on the left-hand side, relative to the feature orientation. |
Right |
- Although area geometry is accepted, the labels are placed along the perimeter of the feature which may be undesirable. Consider using a LabelPointReplacer instead.
- Point geometry will be rejected. Consider using a LabelPointReplacer or TextAdder.
- Awkwardly angled labels might be improved by adjusting spacing or using a Generalizer on the input feature before labeling.
Creating and Modifying Point and Text Features
These transformers work with points, text, and labels in a variety of ways.
Transformer |
Use this to... |
Transformer Description |
Create one or more new features with box geometry of a specific size and position (when Geometry Object is Point or Text). |
Replace a feature’s geometry with a point at a specified location. |
Creates a single vertex to replace, be appended to, or be inserted into existing geometry. |
Create points inside features or their bounding boxes. |
Replaces feature geometry with a point located within the feature, its bounding box, or at its center of mass. |
Extract the coordinates of a calculated point within the feature. |
Extracts the coordinates of a point located within the feature, its bounding box, or at its center of mass, and stores them as attributes. |
Create new regularly-spaced points in a specified location. |
Create new regularly-spaced points over the extents of other features. |
Create points from every vertex of input line or area geometry. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Create points where features intersect. |
Computes intersections between all input features, breaking lines and polygons wherever an intersection occurs and creating nodes at those locations. |
Create points from point cloud features. |
Label lines. |
Places labels along a linear feature, angled to the orientation of each labeled segment. |
Label points at an angle. |
Replaces any geometry with a single text label at the center of its bounding box. |
Label points and areas. |
Replaces point, line, or area geometry with a single text label. |
Convert text to geometry. |
Replaces text with its location geometry, usually a point. |
Extract text properties into attributes. |
Retrieves text property values from text geometry, adding them to the feature as attributes. |
Set or modify text properties. |
Modifies or creates text geometry according to new coordinates, text string, size, or rotation values. |
Convert text to non-text geometry. |
Converts text to aggregate line or area geometry according to a specific True Type font. |
Extract point properties into attributes. |
Extracts point orientation to feature attributes. |
Set or modify point properties. |
Adds or removes point orientation. |
Geometry |
Recommended Transformer |
Example |
Point |
Line |
Area
Features with linear geometry to be labeled.
Features with text geometry according to parameters.
Features without valid line, path, or area geometry are output via this port.
MISSING_FEATURE_ATTRIBUTES
INVALID_PARAMETER_LABEL_OFFSET
INVALID_PARAMETER_LABEL_SPACING
Label |
Specify the label text string. |
Prevent Label Overlaps |
Select a method for handling overlapping labels:
Label Position |
Select a method for placing label insertion points when Label Offset is greater than zero (0):
See Label Positioning above. When Label Offset is zero (0), label points are placed on the feature. Regardless of insertion point position, the label text is placed above or to the right of the point. See Label Orientation above. |
Label Offset |
Specify the distance (in ground units) between the feature and the label insertion point. An offset of zero (0) places label points on the line. |
Labels at End Points |
Select an option for placing labels at the start and end points of the feature:
Label Height |
Specify the height of the text in ground units. |
Average Character Width |
An average single character width (in ground units) may be specified to approximate the size of labels for a specific destination system or font. The default value is zero (0), which is interpreted as the width being equal to the Label Height. When Prevent Label Overlaps is Yes, the resulting dimensions (based on the label text) are used to determine if labels are kept or discarded to avoid collisions. Note that this setting does not alter how text is displayed in the FME Data Inspector, and the resulting labels may appear to overlap. |
Label Spacing |
Specify the interval (in ground units) at which labels should be placed, subject to the Prevent Label Overlaps and Labels at End Points parameters. If set to zero (0) a single label will be placed. |
Minimum Length |
Specify the minimum length a feature must be in order to be labeled. The default is zero (0), which labels all features. |
Label Rotation |
Name the attribute to contain the text orientation in degrees. See Label Orientation above. |
Parallel Rotation |
Name the attribute to contain the orientation of the labeled line segment in degrees. See Label Orientation above. |
Dependencies | None |
Aliases | |
History |
Search for all results about the Labeler on the FME Community.
