FME Transformers: 2025.1
LabelPointReplacer
- Labeling areas and points
The LabelPointReplacer receives area, point, or linear features and replaces them with a single text label. Label height is specified in ground units.
Label position and orientation varies according to the input geometry.
Input Geometry |
Label Placement |
Result |
Point
Label is placed on the point.
Line
Label is placed at the mid-point of the line, angled to the orientation of the line segment at that location. Note that the Labeler is generally recommended for labeling lines. |
Area
Label is placed somewhere within the polygon.
Area - Irregular
Area - Donut
Label is placed somewhere within the polygon but outside any donut holes.
Collision avoidance is not available in this transformer - labels may overlap.
The Labeler is generally more useful for labeling lines.
Creating and Modifying Point and Text Features
These transformers work with points, text, and labels in a variety of ways.
Transformer |
Use this to... |
Transformer Description |
Create one or more new features with box geometry of a specific size and position (when Geometry Object is Point or Text). |
Replace a feature’s geometry with a point at a specified location. |
Creates a single vertex to replace, be appended to, or be inserted into existing geometry. |
Create points inside features or their bounding boxes. |
Replaces feature geometry with a point located within the feature, its bounding box, or at its center of mass. |
Extract the coordinates of a calculated point within the feature. |
Extracts the coordinates of a point located within the feature, its bounding box, or at its center of mass, and stores them as attributes. |
Create new regularly-spaced points in a specified location. |
Create new regularly-spaced points over the extents of other features. |
Create points from every vertex of input line or area geometry. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Create points where features intersect. |
Computes intersections between all input features, breaking lines and polygons wherever an intersection occurs and creating nodes at those locations. |
Create points from point cloud features. |
Label lines. |
Places labels along a linear feature, angled to the orientation of each labeled segment. |
Label points at an angle. |
Replaces any geometry with a single text label at the center of its bounding box. |
Label points and areas. |
Replaces point, line, or area geometry with a single text label. |
Convert text to geometry. |
Replaces text with its location geometry, usually a point. |
Extract text properties into attributes. |
Retrieves text property values from text geometry, adding them to the feature as attributes. |
Set or modify text properties. |
Modifies or creates text geometry according to new coordinates, text string, size, or rotation values. |
Convert text to non-text geometry. |
Converts text to aggregate line or area geometry according to a specific True Type font. |
Extract point properties into attributes. |
Extracts point orientation to feature attributes. |
Set or modify point properties. |
Adds or removes point orientation. |
Geometry |
Recommended Transformer |
Example |
Point |
Line |
Area
Features with valid point, line, or area geometry to be labeled.
Features with text geometry according to parameters.
Features without valid line, path, or area geometry are output via this port.
MISSING_FEATURE_ATTRIBUTES
Label |
Specify the label text string. |
Label Height |
Specify the height of the text in ground units. |
Always Rotate Label |
When labeling lines only:
| Aliases | LabelPointCreator TextReplacer |
Search for all results about the LabelPointReplacer on the FME Community.
