FME Transformers: 2025.1
PointCloudToPointCoercer
Converts point clouds to point or multipoint geometries, optionally retaining attribute and component values.
- Converting point cloud geometry type for storage in formats that do not support point clouds
- Performing spatial or other operations between point cloud points and other data types such as vectors
The PointCloudToPointCoercer receives point cloud features and converts their individual points into either point or multipoint geometry.
Attributes from the point cloud feature may be optionally retained.
Individual component values may also be retained. When converting to individual points, they may be preserved as either attributes or measures. When converting to multipoint, they may be preserved as measures only, and so string components are not supported in this case.
Position, ordering, or area may be used to determine how points are allocated when producing more than one multipoint output feature.
Point or multipoint geometries are output, and the original point cloud is discarded.
In this example, we will convert a point cloud feature into individual points for further processing. Note that the original point cloud has over six million points, and thirteen components - some of which we want to keep.
The point cloud is routed into a PointCloudToPointCoercer.
In the parameters dialog, we set Output Geometry to Individual Points and select some Point Components to Preserve. Note that these will be stored as attributes.
Preserve Attributes is set to No, as the attributes this refers to are those that apply to the entire point cloud feature, and not the individual points. We do not need them.
The output consists of the expected 6,750,386 individual point geometries, viewed here zoomed in closely in the FME Data Inspector. Note that the geometry type has changed to point; the x, y, and z coordinates have been retained; and the requested components and values are attributes.
- The transformer cannot detect the names or existence of any given component on the input point cloud feature. A PointCloudPropertyExtractor transformer may be used to check for the existence of components.
- Point clouds are processed very efficiently in FME. Coercing them to points with this transformer can greatly impact performance negatively. Many transformers support point cloud geometry, and it is recommended to look for workflows without coercing first.
Point or multipoint features with attributes or measures as specified.
INVALID_FEATURE_COMPONENTS
INVALID_GEOMETRY_NUMBER_OF_POINTS
Output Geometry |
Select the geometry type and point allocation method (if multipoint).
Maximum Points Per Multipoint |
When Output Geometry is set to a multipoint option, specify the maximum number of points in output multipoint geometries. |
Preserve Point Components As |
When Output Geometry is Individual Points, specify whether point cloud components should be preserved as attributes or measures. |
Preserve Attributes
Specifies whether attributes of the input feature should be preserved on the output features. Note that this does not affect component preservation - it applies to attributes of the input point cloud feature as a whole. |
Point Components to Preserve |
The list of components to preserve. Standard component names may be selected from the drop-down. User-specified component names must be entered directly. These components and their values will be preserved either as attributes or measures, depending on the Output Geometry and Preserve Point Components As parameter selections. |
Part Number |
Name the attribute to contain each feature's part number. For each input feature, the first output feature will be part 0, the second will be part 1, and so on. |
Dependencies | None |
Aliases | PointCloudCoercer |
History |
Search for all results about the PointCloudToPointCoercer on the FME Community.
