FME Transformers: 2025.1 BETA
Categories
Point Clouds
Related Transformers
Generalizer
PointCloudSimplifier
Sampler
PointCloudThinner
Reduces the number of points in (thins) a point cloud by keeping points at a fixed interval, a maximum number of points, or a set quantity of first or last points. Remaining points are discarded.
Jump to Configuration
  • Reducing the data volume of a point cloud feature to meet processing or storage requirements.
  • Creating a sample point cloud dataset for testing
The PointCloudThinner receives point cloud features and outputs them with fewer points than the original.
The Points to Keep are identified by a fixed interval, a maximum number of points, or by specifying a first or last number of points:
Thinning Type Amount Result
Every Nth Point (Interval)
5
Every 5th point of the input cloud feature will be present in the output point cloud.
Every Nth Point (Maximum Number of Points)
100
The output cloud will have a maximum of 100 points, evenly spaced throughout the input.
First N Points
100
The first 100 points from the input will be kept.
Last N Points
500
The last 500 points from the input will be kept.
  • For finer control over how a point cloud is reduced, consider using the PointCloudSimplifier transformer. It reduces while maintaining the overall shape of the original point cloud feature, however, may take considerably more processing time.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases PointCloudSampler
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the PointCloudThinner on the FME Community.
