FME Transformers: 2025.1 BETA
Categories
Point Clouds
Related Transformers
PointCloudComponentAdder
PointCloudComponentCopier
PointCloudComponentRemover
PointCloudComponentRenamer
PointCloudComponentTypeCoercer
PointCloudComponentKeeper
Keeps only specified point cloud components, discarding all others.
Jump to Configuration
  • Removing unused components
  • Removing components to meet processing or format requirements
  • Removing components to increase processing efficiency or optimize storage
The PointCloudComponentKeeper receives point cloud features, removes all components except those specified in the Components To Keep table, and outputs the modified point cloud.
Standard component names may be selected from drop-down menus, whereas user-specified names must be entered directly..
  • The PointCloudComponentRemover and PointCloudComponentKeeper perform similar functions. The PointCloudComponentKeeper is more useful when removing a proportionately large number of components, whereas the PointCloudComponentRemover is more useful when removing a small number of components.
  • The transformer cannot detect the names or existence of any given component on the input point cloud feature. A PointCloudPropertyExtractor may be used to check for the existence of components.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the PointCloudComponentKeeper on the FME Community.
