FME Transformers: 2025.1 BETA
Categories
Point Clouds
Related Transformers
PointCloudComponentAdder
PointCloudComponentCopier
PointCloudComponentKeeper
PointCloudComponentRemover
PointCloudComponentRenamer
Renames an existing component.
Jump to Configuration
  • Renaming components to meet processing or format requirements.
The PointCloudComponentRenamer receives point cloud features, changes the names of selected existing components, and then outputs the modified point cloud feature.
Components may be renamed to standard component names or user-defined names. If a target component name (the new name) is already in use, that component will be overwritten.
Multiple components may be renamed at once.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the PointCloudComponentRenamer on the FME Community.
