RasterStatisticsCalculator
Calculates statistics on raster bands and adds the results as attributes.
- Inspecting and analyzing raster features
- Checking the results of other transformers such as the RasterExpressionEvaluator or RasterSingularCellValueCalculator
- Calculating statistics for use in further operations
The RasterStatisticsCalculator receives raster features and calculates selected statistics on them individually. The results are output on each raster, and may be generated for Band, Palette, or both.
Available statistics include:
- Minimum
- Maximum
- Mean
- Sum
- Range
- Standard Deviation
- Median
- Mode
Band statistics are stored as attributes, named <band>.<statisticname>.
Palette statistics are calculated on resolved palette values, and are stored as list attributes, named <band>.<palette>.<statisticname>.
For both types of attribute, <statisticname> will be one of the following: min, max, range, mean, stdev, sum, median, mode.
For multi-band rasters, any additional bands beyond Band 0 must be explicitly specified for inclusion in the parameters dialog - Statistics to Calculate table, under Band Index.
To calculate raster statistics on a group of rasters as a single entity, merge them prior to this transformer with the RasterBandCombiner or RasterMosaicker.
In this example, we will generate some statistics on an elevation raster. The source data has elevation values (in meters) stored in Band 0.
The DEM is routed into a RasterStatisticsCalculator.
In the parameters dialog, Raster Level Statistics is set to Band. By default, Band Index 0 is included in the Statistics to Calculate table, and we choose our desired statistics.
The output feature has new attributes containing the requested statistics. Note that the entire raster is selected here, not an individual cell.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterCellOriginSetter | Sets the raster's cell origin. |
| RasterConvolver |
| RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering the extents of the raster. |
| RasterGCPExtractor | Extracts the coordinate system and the Ground Control Points (GCP) from the raster feature and exposes them as attributes. |
| RasterGCPSetter | Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate. |
| RasterGeoreferencer | Georeferences a raster using the specified parameters. |
| RasterHillshader | Generates a shaded relief effect, useful for visualizing terrain. |
Alters the underlying interpretation of the bands of the raster geometry on the input features, using the specified conversion options. For example, an input raster feature with three bands of interpretation (UInt16, Gray8, and Real64) could be converted to a raster feature with three bands of interpretation (Red8, Green8, and Blue8) or four bands of interpretation (Red16, Green16, Blue16, and Alpha16) in a single operation. |
| RasterRotationApplier |
Applies the raster rotation angle on the input raster properties to the rest of the raster properties and data values. The expected input is a raster with a non-zero rotation angle and the expected output is a rotated raster with a rotation angle of 0.0. It is expected that the input raster properties will be modified to conform the output raster properties for a raster rotated by the given angle. Applying a rotation angle is primarily done for compatibility with other processing and writers that cannot handle a rotation angle. |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterCheckpointer | Sets a checkpoint in the raster processing which forces previous processing to occur immediately. Once complete, it saves the current state to disk. |
| RasterConsumer | Requests the tile(s) from the raster geometry but no actual operations are performed on the tile(s). |
| RasterExtractor | Serializes the geometry of the feature into the Blob Attribute based on the selected writer format. |
| RasterNumericCreator | Creates a feature with a raster of the specified size with a numeric value and sends it into the workspace for processing. It is useful for creating a very large image with a user-specified width and height. |
| RasterReplacer | Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected raster format. |
| RasterRGBCreator | Creates a feature with a raster of the specified size with an RGB value and sends it into the workspace for processing. |
| RasterSelector |
Vectors and Rasters
| NumericRasterizer | Draws input point, line and polygon features onto a numeric raster filled with the background value. The Z coordinates of the input vector features are used to generate pixel values. Features without Z coordinates will be discarded. |
This transformer accepts only raster features. Palettes are supported.
Raster features with the specified calculated statistics.
Band statistics are stored as standard attributes, and Palette statistics are stored as list attributes.
INVALID_RASTER_NO_BANDS
INVALID_RASTER_CANNOT_CREATE_POINT_CLOUD
| Raster Level Statistics |
Specifies for all bands chosen: whether to calculate statistics on band values, resolved palette values, or both. If Band is selected and a band with palette(s) is encountered, statistics will be calculated on the band’s cell values. If Palette is selected and a band with no palette is encountered, no statistics will be calculated for that band. If Band and Palette is selected, statistics will be calculated for bands without palettes, bands with palettes will calculate resolved palette values and cell values. |
Specifies which statistics to calculate for each band.
| Band Index |
Bands are specified by their index number, starting at 0. Band 0 is included by default, and any additional bands must be explicitly specified for inclusion. |
| Statistics |
The following statistics may be calculated:
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the RasterStatisticsCalculator on the FME Community.
