RasterBandNodataSetter
Sets a new nodata value on selected bands of a raster feature.
Jump to Configuration
  • Defining a nodata value for a raster that does not currently have one set, excluding cells with that value from display or processing.
  • Changing the nodata value on a raster.
The RasterBandNodataSetter receives raster features, and adds or changes the nodata property on any selected bands. If a band already has a nodata value, cells with that value may optionally be changed to the new provided value.
Nodata represents an absence of data, and cells that have (or receive) the new nodata value are ignored for most calculations, and are transparent when viewed in the FME Data Inspector and many other visualization tools.
All selected bands on an input raster feature will receive the same specified nodata value.
To select specific bands, use the RasterSelector prior to the RasterBandNodataSetter.
This transformer supports raster band selection. Palettes are unaffected.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Professional Edition and above
Aliases
History
Categories
Rasters
Search for all results about the RasterBandNodataSetter on the FME Community.
