RasterCellValueReplacer
Replaces a range of band values in a raster with a new single value.
- Classifying cell value ranges
- Adjusting image threshold
The RasterCellValueReplacer receives raster features. Each band value of each cell is compared to a defined set of numeric ranges, and values that match the range definition are replaced with a new, single defined value.
Range(s) are defined by one or two parameters, which may be combined in a variety of ways. If both parameters are defined, both are applied. These examples assume that the band values are integers.
Example |
Replace Values >= (greater than or equal to) |
Replace Values <= (less than or equal to) |
| Find values from 10 to 20 , inclusive | 10 | 20 |
| Find the single value 45 | 45 | 45 |
| Everything except the value 45 | 46 | 44 |
| Find values less than 100 | <blank> | 99 |
| Find values of 50 or greater | 50 | <blank> |
| Find two distinct ranges at the upper and lower limits, values 50 and below, and values more than 99 (everything outside a range) | 99 | 50 |
| Replace all values | 0 | <blank> |
The new value may be defined as a single value, or as an expression.
For multi-band rasters, each band is processed identically on every cell, comparing the individual band values to the defined range(s). For example, if the range is <= 100, with a replacement value of 25, an RGB value of 14,87,192 becomes 25,25,192. To restrict operation to specific band(s), use a RasterSelector prior to the RasterCellValueReplacer.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
In this example, we will identify the range of elevation values less than 15 meters, and apply a single value (zero) to all cells that fall within that range, simulating a 15 meter sea level rise. The source data is a DEM in GeoTIFF format. Elevation is stored as the Band 0 value.
The DEM is routed into a RasterCellValueReplacer.
In the parameters dialog, we define a range of values less than or equal to 15. The new value is 0.
A raster feature is output, and all cells with elevations that fell within the range now have an elevation value of 0.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterCellOriginSetter | Sets the raster's cell origin. |
| RasterConvolver |
| RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering the extents of the raster. |
| RasterGCPExtractor | Extracts the coordinate system and the Ground Control Points (GCP) from the raster feature and exposes them as attributes. |
| RasterGCPSetter | Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate. |
| RasterGeoreferencer | Georeferences a raster using the specified parameters. |
| RasterHillshader | Generates a shaded relief effect, useful for visualizing terrain. |
Alters the underlying interpretation of the bands of the raster geometry on the input features, using the specified conversion options. For example, an input raster feature with three bands of interpretation (UInt16, Gray8, and Real64) could be converted to a raster feature with three bands of interpretation (Red8, Green8, and Blue8) or four bands of interpretation (Red16, Green16, Blue16, and Alpha16) in a single operation. |
| RasterRotationApplier |
Applies the raster rotation angle on the input raster properties to the rest of the raster properties and data values. The expected input is a raster with a non-zero rotation angle and the expected output is a rotated raster with a rotation angle of 0.0. It is expected that the input raster properties will be modified to conform the output raster properties for a raster rotated by the given angle. Applying a rotation angle is primarily done for compatibility with other processing and writers that cannot handle a rotation angle. |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterCheckpointer | Sets a checkpoint in the raster processing which forces previous processing to occur immediately. Once complete, it saves the current state to disk. |
| RasterConsumer | Requests the tile(s) from the raster geometry but no actual operations are performed on the tile(s). |
| RasterExtractor | Serializes the geometry of the feature into the Blob Attribute based on the selected writer format. |
| RasterNumericCreator | Creates a feature with a raster of the specified size with a numeric value and sends it into the workspace for processing. It is useful for creating a very large image with a user-specified width and height. |
| RasterReplacer | Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected raster format. |
| RasterRGBCreator | Creates a feature with a raster of the specified size with an RGB value and sends it into the workspace for processing. |
| RasterSelector |
Vectors and Rasters
| NumericRasterizer | Draws input point, line and polygon features onto a numeric raster filled with the background value. The Z coordinates of the input vector features are used to generate pixel values. Features without Z coordinates will be discarded. |
Raster feature(s) containing cells with values to be replaced.
Raster features with cell values replaced according to parameter selections.
INVALID_RASTER_NO_BANDS
| Replace Values >= | Specifies a range bounded by a minimum value, where all values greater than or equal to the supplied value will be replaced by the replacement value. |
| Replace Values <= | Specifies a range bounded by a maximum value, where all values less than or equal to the supplied value will be replaced by the replacement value. |
| New Value | Specifies the new value that will replace the specified range. |
| Replace Nodata | Specifies whether nodata values will be replaced. If set to Yes, nodata values will be replaced just as any other values. If set to No, then nodata values will not be replaced, even if they fall within the specified bounds. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the RasterCellValueReplacer on the FME Community.
