RasterGCPExtractor
Extracts the coordinate system and the Ground Control Points (GCP) from the raster feature and exposes them as attributes.
Output
The output attribute of this transformer is encoded as follows:
pixel line x y z;pixel line x y z etc.
The following raster properties are exposed:
_gcp_coordsys
_gcp_value
None.
Transformer Categories
FME Licensing Level
Technical History
Associated FME function or factory: @RasterGCP
Search FME Community
