RasterGeoreferencer
Georeferences a raster using the specified parameters.
The Parameter Type determines which parameters are required in this transformer.
Parameter Type
Point And Angle: X Upper Left Coordinate, Y Upper Left Coordinate, X Cell Spacing, Y Cell Spacing and Rotation will be used.
In this case, the raster's origin will be set to the upper left coordinate and X Cell Spacing, Y Cell Spacing and Rotation are stored as input, untouched.
Extents: X Upper Left Coordinate, Y Upper Left Coordinate, X Upper Right Coordinate, Y Upper Right Coordinate, X Lower Right Coordinate, Y Lower Right Coordinate, X Lower Left Coordinate and Y Lower Left Coordinate will be used.
- If the raster is already georeferenced, this will overwrite the old georeferencing information.
- This transformer is unaffected by raster band and palette selection.
Example
Transformer Categories
FME Licensing Level
Technical History
FME Factory Used: @GeoreferenceRaster
Search FME Community
