RasterBandSeparator
Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations.
- Isolating bands or palettes to meet format or processing requirements.
The RasterBandSeparator receives raster features and separates their bands and palettes into individual output raster features.
Raster features may be split by band, band and palette, or palette.
Separating by Band Only will produce multiple output features, one for each band.
Separating by Band and Palette will also produce multiple output features, one for every unique band and palette combination.
Separating by Palette Only will produce a single output feature per input feature, containing bands for every unique band and palette combination.
Attributes may be created to record which raster, band, and/or palette from which the output feature originated.
The order of the input features and their bands and palettes will determine the order of the output features. A Sorter transformer may be used to set the order in which the features are processed.
In this example, we will separate a multi-band orthoimage into its component bands.
Note that the original raster has three bands - red, green, and blue.
The raster is routed into a RasterBandSeparator.
In the parameters dialog, Split By is set to Band Only, and the Attributes to add remain with their default names.
Three raster features are output, one for each band in the input feature. Note that the feature viewed here in the FME Data Inspector was produced by the red band, and contains only that single band.
In table view, the three output features are listed. The _raster_index attribute indicates that all were created from the first raster feature received (0). The _band_index attribute refers to the original band, where 0 is red, 1 is green, and 2 is blue.
The input raster has no palettes, and therefore the _palette_index attribute is missing.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterCellOriginSetter | Sets the raster's cell origin. |
| RasterConvolver |
| RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering the extents of the raster. |
| RasterGCPExtractor | Extracts the coordinate system and the Ground Control Points (GCP) from the raster feature and exposes them as attributes. |
| RasterGCPSetter | Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate. |
| RasterGeoreferencer | Georeferences a raster using the specified parameters. |
| RasterHillshader | Generates a shaded relief effect, useful for visualizing terrain. |
Alters the underlying interpretation of the bands of the raster geometry on the input features, using the specified conversion options. For example, an input raster feature with three bands of interpretation (UInt16, Gray8, and Real64) could be converted to a raster feature with three bands of interpretation (Red8, Green8, and Blue8) or four bands of interpretation (Red16, Green16, Blue16, and Alpha16) in a single operation. |
| RasterRotationApplier |
Applies the raster rotation angle on the input raster properties to the rest of the raster properties and data values. The expected input is a raster with a non-zero rotation angle and the expected output is a rotated raster with a rotation angle of 0.0. It is expected that the input raster properties will be modified to conform the output raster properties for a raster rotated by the given angle. Applying a rotation angle is primarily done for compatibility with other processing and writers that cannot handle a rotation angle. |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterCheckpointer | Sets a checkpoint in the raster processing which forces previous processing to occur immediately. Once complete, it saves the current state to disk. |
| RasterConsumer | Requests the tile(s) from the raster geometry but no actual operations are performed on the tile(s). |
| RasterExtractor | Serializes the geometry of the feature into the Blob Attribute based on the selected writer format. |
| RasterNumericCreator | Creates a feature with a raster of the specified size with a numeric value and sends it into the workspace for processing. It is useful for creating a very large image with a user-specified width and height. |
| RasterReplacer | Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected raster format. |
| RasterRGBCreator | Creates a feature with a raster of the specified size with an RGB value and sends it into the workspace for processing. |
| RasterSelector |
Vectors and Rasters
| NumericRasterizer | Draws input point, line and polygon features onto a numeric raster filled with the background value. The Z coordinates of the input vector features are used to generate pixel values. Features without Z coordinates will be discarded. |
Raster features according to the raster and palette separation specifications.
INVALID_RASTER_NO_BANDS
| Split By |
Band Only: Each band on the input raster feature will be placed onto a unique output raster feature. Each output raster feature will have no more than one band, but each band may have multiple palettes. Band and Palette: Each unique combination of band and palette will be output to a separate raster feature. A band with multiple palettes will be output multiple times, once for each palette. Each output raster feature will have no more than one band and no more than one palette. Palette Only: One raster feature is output per input feature, containing one band for every unique combination of band and palette. A band with multiple palettes will be output multiple times, once for each palette. Each output raster feature may have multiple bands but will have no more than one palette per band. |
When using Split By - Band Only or Band and Palette, attributes may be added to the output raster to specify which raster, band, and palette it originated from.
Default attribute names are provided. If an attribute name is blank, it will not be added to the output features.
| Raster Index Attribute | Name the attribute to contain the index of the original input raster feature. |
| Band Index Attribute | Name the attribute to contain the index of the original raster band. |
| Palette Index Attribute | Name the attribute to contain the index of the original raster palette. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| Aliases | RasterBandSplitter |
| History | This transformer was previously known as the RasterBandSplitter. |
| Categories |
Search for all results about the RasterBandSeparator on the FME Community.
