RasterPaletteResolver
Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands.
- Applying palette values to cells to meet format or processing requirements.
- Preparing rasters with palettes to be written to formats that do not support palettes.
The RasterPaletteResolver receives raster features and, for all selected bands, resolves palette values onto bands by replacing cell values with their corresponding palette values. Palettes are removed from the output raster features.
If the palette values have multiple parts, as in RGB palettes, each component part is placed on a separate band, with new bands added as necessary to accommodate them. For example, an input raster feature that has one band with an RGB24 palette will produce an output raster feature with three bands - RED8, GREEN8, and BLUE8 - and no palettes.
This transformer supports raster band selection only. All palettes on the selected band(s) will be resolved. The RasterSelector can be used to modify selection.
If more than one palette is to be resolved, additional bands are added. Band order will reflect the original palette order.
String palettes cannot be resolved, as cell values must be numeric. They should be removed prior to the RasterPaletteResolver, using a RasterSelector and RasterPaletteRemover.
In this example, we have a single-band raster with one RGB palette, and want to resolve the palette values.
Note that the cell selected below has a value of 8, which points to the RGB palette value 253,218,236.
The raster is routed into a RasterPaletteResolver.
There are no parameters to be configured.
The output raster feature has three bands - red, green, and blue - and no palettes. Note that the new bands have retained the raster’s original Nodata Value, which may need to be removed in a subsequent step.
The cell value, previously 8, has been replaced with the palette component values assigned to the appropriate bands.
- New bands duplicate most properties of the original band, including Nodata Value, which may need to be removed or altered after palettes are resolved by using a RasterBandNodataRemover or RasterBandNodataSetter.
- String palettes cannot be resolved and must be removed from selected bands prior to using this transformer, but they may be preserved by using a RasterPaletteExtractor to extract them (as a string) to an attribute That attribute may also be written to a file using an AttributeFileWriter.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterCellOriginSetter | Sets the raster's cell origin. |
| RasterConvolver |
| RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering the extents of the raster. |
| RasterGCPExtractor | Extracts the coordinate system and the Ground Control Points (GCP) from the raster feature and exposes them as attributes. |
| RasterGCPSetter | Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate. |
| RasterGeoreferencer | Georeferences a raster using the specified parameters. |
| RasterHillshader | Generates a shaded relief effect, useful for visualizing terrain. |
Alters the underlying interpretation of the bands of the raster geometry on the input features, using the specified conversion options. For example, an input raster feature with three bands of interpretation (UInt16, Gray8, and Real64) could be converted to a raster feature with three bands of interpretation (Red8, Green8, and Blue8) or four bands of interpretation (Red16, Green16, Blue16, and Alpha16) in a single operation. |
| RasterRotationApplier |
Applies the raster rotation angle on the input raster properties to the rest of the raster properties and data values. The expected input is a raster with a non-zero rotation angle and the expected output is a rotated raster with a rotation angle of 0.0. It is expected that the input raster properties will be modified to conform the output raster properties for a raster rotated by the given angle. Applying a rotation angle is primarily done for compatibility with other processing and writers that cannot handle a rotation angle. |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterCheckpointer | Sets a checkpoint in the raster processing which forces previous processing to occur immediately. Once complete, it saves the current state to disk. |
| RasterConsumer | Requests the tile(s) from the raster geometry but no actual operations are performed on the tile(s). |
| RasterExtractor | Serializes the geometry of the feature into the Blob Attribute based on the selected writer format. |
| RasterNumericCreator | Creates a feature with a raster of the specified size with a numeric value and sends it into the workspace for processing. It is useful for creating a very large image with a user-specified width and height. |
| RasterReplacer | Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected raster format. |
| RasterRGBCreator | Creates a feature with a raster of the specified size with an RGB value and sends it into the workspace for processing. |
| RasterSelector |
Vectors and Rasters
| NumericRasterizer | Draws input point, line and polygon features onto a numeric raster filled with the background value. The Z coordinates of the input vector features are used to generate pixel values. Features without Z coordinates will be discarded. |
Raster features with palette values resolved onto bands, with new bands added as required.
INVALID_RASTER_NO_BANDS
INVALID_RASTER_CANNOT_RESOLVE
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the RasterPaletteResolver on the FME Community.
