Calculates the slope (maximum rate of change in z) for each cell of a raster.
- Calculating slope on elevation rasters
- Calculating the rate of change on raster band values
The RasterSlopeCalculator receives raster features, and calculates the slope for each cell.
Slope may be measured in either Degrees (0 to 90), or Percent Rise (0 to infinity). The calculation is done based on the values of surrounding cells (using a 3 cell x 3 cell window), and a choice of algorithms is available. Cells without data (nodata) may be interpolated for calculation purposes.
Slope values are output on the same band they were calculated from, and the band is converted to Real64.
For multi-band rasters, each band is processed separately, with slope values calculated for each band on each cell. To restrict operation to specific band(s), use a RasterSelector prior to the RasterSlopeCalculator.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
Z Factor, Scaling and Units
Input rasters’ horizontal (x and y) units are expected to be the same as vertical (z) units.
If this is not the case - for example, if the horizontal units are in meters with elevation (z) in feet (or any other similar unit type mismatch), you may apply a scale factor (also known as Z Factor) with the Scaler transformer prior to using a RasterSlopeCalculator.
In this example (ground units are meters, elevations are feet), the scale factor to use is 0.3048 - the number of meters in one foot.
If the ground units are lat/long, the appropriate scale factor will vary greatly between the equator and the poles. In this case, consider reprojecting the input raster with a Reprojector, to an appropriate coordinate system with ground units matching the vertical (z) units.
 Example: Slope calculation on a DEM
                                        In this example we will perform a slope calculation on a Digital Elevation Model. The source data ranges in elevation from sea level (0) to around 1500 meters, in a mountainous area. Note that elevation is stored in Band 0, as an integer.
Note: This format, CDED, is in an LL83-SECONDS coordinate system - and so the lat/long horizontal (ground) units do not match the vertical (elevation) units in meters.
The DEM is routed first into a Reprojector, where it is converted to UTM83-10, an appropriate local coordinate system with ground units in meters, matching the elevation value units. Then it is routed into a RasterSlopeCalculator.
In the parameters dialog, we select an Output Measurement of Degrees, and use the Horn algorithm. Interpolate Nodata is set to Yes.
The output raster feature has new Band 0 values - the calculated slope - and the band has been converted to a floating point decimal interpretation type (real64).
Note the shape of the output raster compared to the original DEM data - a result of the reprojection.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
 Raster Transformers
Raster Transformers
                                        Working with Rasters
 These transformers generally apply to whole rasters.
                                                | RasterCellOriginSetter | Sets the raster's cell origin. |
| RasterConvolver | Applies a convolution filter (sometimes called a kernel or lens) to raster features and outputs the results. |
| RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering the extents of the raster. |
| RasterGCPExtractor | Extracts the coordinate system and the Ground Control Points (GCP) from the raster feature and exposes them as attributes. |
| RasterGCPSetter | Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate. |
| RasterGeoreferencer | Georeferences a raster using the specified parameters. |
| RasterHillshader | Generates a shaded relief effect, useful for visualizing terrain. |
| RasterInterpretationCoercer | Alters the underlying interpretation of the bands of the raster geometry on the input features, using the specified conversion options. For example, an input raster feature with three bands of interpretation (UInt16, Gray8, and Real64) could be converted to a raster feature with three bands of interpretation (Red8, Green8, and Blue8) or four bands of interpretation (Red16, Green16, Blue16, and Alpha16) in a single operation. |
| RasterRotationApplier | Applies the raster rotation angle on the input raster properties to the rest of the raster properties and data values. The expected input is a raster with a non-zero rotation angle and the expected output is a rotated raster with a rotation angle of 0.0. It is expected that the input raster properties will be modified to conform the output raster properties for a raster rotated by the given angle. Applying a rotation angle is primarily done for compatibility with other processing and writers that cannot handle a rotation angle. |
Working with Bands
 These transformers generally apply to bands.
| RasterBandInterpretationCoercer | Alters the interpretation type of individual raster bands, converting cell values if necessary. |
| RasterBandKeeper | Removes all unselected bands from a raster feature. |
Working with Cells
 These transformers generally apply to individual cells.
                                                | RasterAspectCalculator | Calculates the aspect (direction of slope) for each cell of a raster. Aspect is measured in degrees from 0 to 360, clockwise from north. |
Working with Palettes
 These transformers generally apply to palettes.
                                                | RasterPaletteAdder | Creates a palette from an attribute, and adds this palette to all selected bands on a raster. |
| RasterPaletteInterpretationCoercer | Alters the interpretation type of raster palettes. |
| RasterPaletteNodataSetter | Identifies the palette key that matches a raster band’s nodata value, and sets a value on it. |
Workflow Control
 These transformers generally control the flow of features in a workspace.
                                                | RasterCheckpointer | Sets a checkpoint in the raster processing which forces previous processing to occur immediately. Once complete, it saves the current state to disk. |
| RasterConsumer | Requests the tile(s) from the raster geometry but no actual operations are performed on the tile(s). |
| RasterExtractor | Serializes the geometry of the feature into the Blob Attribute based on the selected writer format. |
| RasterNumericCreator | Creates a feature with a raster of the specified size with a numeric value and sends it into the workspace for processing. It is useful for creating a very large image with a user-specified width and height. |
| RasterReplacer | Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected raster format. |
| RasterRGBCreator | Creates a feature with a raster of the specified size with an RGB value and sends it into the workspace for processing. |
| RasterSelector | Selects specific bands and palettes of a raster for subsequent transformer operations. |
Vectors and Rasters
 These transformers generally involve using rasters and vector data together.
| NumericRasterizer | Draws input point, line and polygon features onto a numeric raster filled with the background value. The Z coordinates of the input vector features are used to generate pixel values. Features without Z coordinates will be discarded. |
 Input
Input
                                        Raster features with cells to calculate slope values on. Horizontal (x and y) units should be the same as vertical (z) units.
 Output
Output
                                        Raster features with calculated slope values, stored in the same band they were provided in, converted to interpretation type real64.
 <Rejected>
<Rejected>
INVALID_RASTER_CANNOT_CALCULATE_SLOPE
                                        | Output Measurement | Select the measurement units of the output slope data. Degrees: Slope will be calculated in degrees. Values will range from 0 (flat) to 90 (vertical). Percent Rise: Slope will be calculated as percent rise. Values will range from 0 (flat) to infinity (vertical). A flat surface will have a slope of 0 percent, a 45 degree surface will have a slope of 100 percent, and as the surface becomes more vertical the slope gets progressively larger. |
| Interpolate Nodata | Calculate values at raster edges and near nodata values. No: When any pixel in the 3x3 window used to calculate the slope value is equal to nodata, the output pixel will also be set to nodata. If the input band does not have a nodata value, the output band nodata value will be set to -1. There will be a one pixel border around the edge of the raster set to the nodata value. Yes: Values around the edge and near nodata values will be estimated by interpolating missing values. Note that holes will not be filled in - cells that are nodata in the input raster will remain nodata in the output. |
| Algorithm | The algorithm used to calculate the slope. Some analyses have suggested that Horn's formula is better suited to rougher terrain, whereas Zevenbergen & Thorne's formula is better for smooth terrain. |
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
 How to Set Parameter Values
 Content Types
Content Types
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| Processing Behavior | |
| Feature Holding | No |
| History | |
| Categories |
Search for all results about the RasterSlopeCalculator on the FME Community.
