RasterSelector
Selects specific bands and palettes of a raster for subsequent transformer operations.
- Isolating specific bands or palettes to perform operations on.
The RasterSelector receives raster features and designates specific bands and palettes as “selected.”
Once a selection is performed, transformers that support raster selection will only affect the selected bands and palettes. Unselected elements are passed through unaltered, and remain in an unselected state until another RasterSelector operation is performed.
The default state of a raster feature is that all bands and palettes are selected - that is, after reading in the raster, subsequent raster transformers will operate on all bands and palettes. Raster transformers may support both band and palette selection, band selection only, or may be unaffected by it. Check a transformer’s documentation for raster selection support details.
Bands and palettes are selected using the band and palette indices, specified in a string. The string may either be entered as a parameter or provided as an attribute.
Selection Strings
The format of the string is B P (band number, then palette number, separated by a space). If the raster does not have palettes, only band numbers should be specified.
- Indices are zero-based, so the first band or palette is at index 0.
- The keyword ALL can be used in place of band and palette numbers to select all bands or all palettes on a specific band.
- Multiple bands or band-palette pairs are separated by a semicolon (;).
- Multiple palettes on one band are separated by a comma (,).
Selection String Examples
All bands |
ALL |
All bands and all palettes |
ALL ALL |
First palette of the first band of a raster |
0 0 |
First palette of the first band and first palette of the third band |
0 0;2 0 |
First three bands of the raster (without palettes) |
0;1;2 |
First three bands of the raster (with their palettes) |
0 ALL;1 ALL;2 ALL |
First two palettes on the first band |
0 0,1 |
- It is possible to select bands without selecting the attached palettes.
- It is NOT possible to select palettes without selecting the owning band.
- Specific palettes cannot be selected on ALL bands; for example, ALL 2.
In this example, we will remove the green band from an RGB raster. The original raster has three bands - red, green, and blue - and no palettes. Note the band index numbers, starting with zero (0). Green is Band 1.
The operation will take three steps (though the third is optional):
- Select the band to be removed.
- Remove the selected band.
- Perform another raster selection, to re-select the remaining bands for further processing (optional).
The raster is first routed into a RasterSelector. In the parameters dialog, Selection Mode is Band and Palette List.
The Band and Palette List is set to 1, which will select the green band (Band 1) only.
Next, the raster passes through a RasterBandRemover. This transformer has no parameters to set, and removes all currently selected bands.
After exiting the RasterBandRemover, the raster feature has no bands selected, as the previously selected band no longer exists. Selection does not generally affect writers, but if further processing is required, the remaining bands need to be re-selected.
Another RasterSelector is added, and the Band and Palette List is set to ALL, selecting all bands.
The output raster feature has only two bands - red and blue. Note that the band index numbering has been reset - Band 1 is now blue.
In this example, we will select a palette to be extracted into an attribute. The source raster has one band, with two palettes - an RGB palette containing colors, and a string palette that contains labels. We are interested in the string palette.
Note that the only band is Band 0, and the string palette is Palette 1.
This operation will take two steps:
- Select the palette of interest, and the band it is on.
- Perform the extraction.
The Band and Palette List is set to 0 1, representing Band 0 and Palette 1, separated by a space.
The next step is the RasterPaletteExtractor. In the parameters dialog, we set a name for a new attribute which will contain the contents of the selected palette, naming it _palette.
The output raster feature has a new attribute, with the contents of the selected palette.
Note that the state of the raster feature as it exits the RasterPaletteExtractor is still one band and one palette selected. If further processing was required, another RasterSelector may be needed to re-select all bands and palettes, as shown in the previous example.
A Band and Palette List of ALL ALL will re-select all bands and palettes.
- This function overrides any existing selection on the raster. All unspecified bands and palettes on a raster after selection are treated as unselected for future operations.
- Selection is not considered by writers, so use the RasterBandSeparator and filtering to write subsets of the bands and palettes as individual features.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterCellOriginSetter | Sets the raster's cell origin. |
| RasterConvolver |
| RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering the extents of the raster. |
| RasterGCPExtractor | Extracts the coordinate system and the Ground Control Points (GCP) from the raster feature and exposes them as attributes. |
| RasterGCPSetter | Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate. |
| RasterGeoreferencer | Georeferences a raster using the specified parameters. |
| RasterHillshader | Generates a shaded relief effect, useful for visualizing terrain. |
Alters the underlying interpretation of the bands of the raster geometry on the input features, using the specified conversion options. For example, an input raster feature with three bands of interpretation (UInt16, Gray8, and Real64) could be converted to a raster feature with three bands of interpretation (Red8, Green8, and Blue8) or four bands of interpretation (Red16, Green16, Blue16, and Alpha16) in a single operation. |
| RasterRotationApplier |
Applies the raster rotation angle on the input raster properties to the rest of the raster properties and data values. The expected input is a raster with a non-zero rotation angle and the expected output is a rotated raster with a rotation angle of 0.0. It is expected that the input raster properties will be modified to conform the output raster properties for a raster rotated by the given angle. Applying a rotation angle is primarily done for compatibility with other processing and writers that cannot handle a rotation angle. |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterCheckpointer | Sets a checkpoint in the raster processing which forces previous processing to occur immediately. Once complete, it saves the current state to disk. |
| RasterConsumer | Requests the tile(s) from the raster geometry but no actual operations are performed on the tile(s). |
| RasterExtractor | Serializes the geometry of the feature into the Blob Attribute based on the selected writer format. |
| RasterNumericCreator | Creates a feature with a raster of the specified size with a numeric value and sends it into the workspace for processing. It is useful for creating a very large image with a user-specified width and height. |
| RasterReplacer | Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected raster format. |
| RasterRGBCreator | Creates a feature with a raster of the specified size with an RGB value and sends it into the workspace for processing. |
| RasterSelector |
Vectors and Rasters
| NumericRasterizer | Draws input point, line and polygon features onto a numeric raster filled with the background value. The Z coordinates of the input vector features are used to generate pixel values. Features without Z coordinates will be discarded. |
If a specific band or palette number is specified in the Band and Palette List parameter, that band or palette must exist on the input feature.
Raster features with specified bands and palettes in a selected state.
INVALID_RASTER_NO_BANDS
| Selection Mode |
Band and Palette List: To specify explicit bands and palettes in the Band and Palette List parameter. Attribute: A band and palette selection string will be provided in an attribute. |
| Band and Palette List | Enter a band and palette list string. |
| Attribute | Specify the attribute containing the band and palette list string. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
Transformers that support band or band and palette selection:
RasterBandInterpretationCoercer
RasterPaletteInterpretationCoercer
| Aliases | RasterBandSelector, RasterPaletteSelector |
| History | |
| Categories |
Search for all results about the RasterSelector on the FME Community.
