RasterBandNodataRemover
Removes the existing nodata identifier from selected bands of a raster feature. Any values previously equal to the nodata value are considered valid data.
- Making cells containing the nodata value valid for calculations.
- Making nodata cells visible in a visualization tool that otherwise renders them transparently.
The RasterBandNodataRemover receives raster features, and removes the nodata property from any selected bands. It does not alter cell values.
Cells that have the current nodata value retain their values, and those values become valid for operations such as expression evaluation and statistical analysis.
Nodata represents an absence of data, and cells that have the nodata value are ignored for most calculations, and are transparent when viewed in the FME Data Inspector and many other visualization tools.
If the raster does not have a nodata property defined, it will be unaffected by this transformer.
To select specific bands, use the RasterSelector prior to the RasterBandNodataRemover.
This transformer supports raster band selection. Palettes are unaffected.
In this example, we want to remove the nodata value from a numeric raster that contains slope values calculated from an elevation model.
Note that the source raster has one band, and its Nodata Value has been set to zero (0). As a result, cells with no slope (value of zero) are not displayed, making flat surfaces such as water bodies transparent.
The raster feature is routed into a RasterBandNodataRemover.
The transformer has no parameters to configure.
The output raster no longer has a Nodata Value band property. Any cells that had the original nodata value - zero (0) - still have that value, but they are now considered valid and are displayed.
- To add a nodata property to a raster that does not have one, use the RasterBandNodataSetter.
- To change the existing nodata value to a different value, use the RasterBandNodataSetter.
- To set a nodata value on a palette, use the RasterPaletteNodataSetter.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterCellOriginSetter | Sets the raster's cell origin. |
| RasterConvolver |
| RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering the extents of the raster. |
| RasterGCPExtractor | Extracts the coordinate system and the Ground Control Points (GCP) from the raster feature and exposes them as attributes. |
| RasterGCPSetter | Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate. |
| RasterGeoreferencer | Georeferences a raster using the specified parameters. |
| RasterHillshader | Generates a shaded relief effect, useful for visualizing terrain. |
Alters the underlying interpretation of the bands of the raster geometry on the input features, using the specified conversion options. For example, an input raster feature with three bands of interpretation (UInt16, Gray8, and Real64) could be converted to a raster feature with three bands of interpretation (Red8, Green8, and Blue8) or four bands of interpretation (Red16, Green16, Blue16, and Alpha16) in a single operation. |
| RasterRotationApplier |
Applies the raster rotation angle on the input raster properties to the rest of the raster properties and data values. The expected input is a raster with a non-zero rotation angle and the expected output is a rotated raster with a rotation angle of 0.0. It is expected that the input raster properties will be modified to conform the output raster properties for a raster rotated by the given angle. Applying a rotation angle is primarily done for compatibility with other processing and writers that cannot handle a rotation angle. |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterCheckpointer | Sets a checkpoint in the raster processing which forces previous processing to occur immediately. Once complete, it saves the current state to disk. |
| RasterConsumer | Requests the tile(s) from the raster geometry but no actual operations are performed on the tile(s). |
| RasterExtractor | Serializes the geometry of the feature into the Blob Attribute based on the selected writer format. |
| RasterNumericCreator | Creates a feature with a raster of the specified size with a numeric value and sends it into the workspace for processing. It is useful for creating a very large image with a user-specified width and height. |
| RasterReplacer | Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected raster format. |
| RasterRGBCreator | Creates a feature with a raster of the specified size with an RGB value and sends it into the workspace for processing. |
| RasterSelector |
Vectors and Rasters
| NumericRasterizer | Draws input point, line and polygon features onto a numeric raster filled with the background value. The Z coordinates of the input vector features are used to generate pixel values. Features without Z coordinates will be discarded. |
Raster features with any nodata properties removed from selected bands.
INVALID_RASTER_NO_BANDS
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| Aliases | RasterNodataRemover |
| History | |
| Categories |
Search for all results about the RasterBandNodataRemover on the FME Community.
