RasterResampler
Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, by interpolating new cell values.
Reducing raster resolution (by reducing the number of cells and increasing cell size)
- Coercing a raster to specific dimensions or cell (pixel) size for further processing purposes or to match other data
- Creating thumbnail images of rasters
The RasterResampler accepts raster features and alters the number of rows/columns and resizes cell (pixel) size according to the parameter selections. One raster feature is output for each input feature.
Output raster resolution may be specified by set dimensions (columns and rows), cell size in ground units, or percentage of original resolution.
A variety of methods are available for output cell value interpolation.
A: Original resolution
B: Desired resolution
C: Desired resolution compared to original
D: Resampled output raster
In this example, we will resample an orthophoto. The original raster is 1600 x 1000 pixels, with a cell size (Spacing) of 1,1 - one meter wide by one meter high (the ground units of the projection).
The raster is routed into a RasterResampler.
In the parameters dialog, we select the Size Specification of CellSize. This enables the X and Y Cell Spacing parameters, which are then both set to 25 - meaning 25 meters in ground units.
Interpolation Type is left as the default of Nearest Neighbor.
The output raster covers the same geographic extents as the input, but the cells are now 25 meters square and the resolution has correspondingly decreased to 64 x 40.
- To resize rasters (clipping or padding) without changing the cell size, consider using the RasterSubsetter
- To resample rasters to multiple sizes, consider using the WebMapTiler or the RasterPyramider.
- To split rasters in multiple smaller rasters without changing the cell size, consider using the RasterTiler.
Although this transformer can be used to increase raster resolution, usually there is little benefit in doing so (with an exception being to match the resolution of other raster data for processing purposes).
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterCellOriginSetter | Sets the raster's cell origin. |
| RasterConvolver |
| RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering the extents of the raster. |
| RasterGCPExtractor | Extracts the coordinate system and the Ground Control Points (GCP) from the raster feature and exposes them as attributes. |
| RasterGCPSetter | Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate. |
| RasterGeoreferencer | Georeferences a raster using the specified parameters. |
| RasterHillshader | Generates a shaded relief effect, useful for visualizing terrain. |
Alters the underlying interpretation of the bands of the raster geometry on the input features, using the specified conversion options. For example, an input raster feature with three bands of interpretation (UInt16, Gray8, and Real64) could be converted to a raster feature with three bands of interpretation (Red8, Green8, and Blue8) or four bands of interpretation (Red16, Green16, Blue16, and Alpha16) in a single operation. |
| RasterRotationApplier |
Applies the raster rotation angle on the input raster properties to the rest of the raster properties and data values. The expected input is a raster with a non-zero rotation angle and the expected output is a rotated raster with a rotation angle of 0.0. It is expected that the input raster properties will be modified to conform the output raster properties for a raster rotated by the given angle. Applying a rotation angle is primarily done for compatibility with other processing and writers that cannot handle a rotation angle. |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterCheckpointer | Sets a checkpoint in the raster processing which forces previous processing to occur immediately. Once complete, it saves the current state to disk. |
| RasterConsumer | Requests the tile(s) from the raster geometry but no actual operations are performed on the tile(s). |
| RasterExtractor | Serializes the geometry of the feature into the Blob Attribute based on the selected writer format. |
| RasterNumericCreator | Creates a feature with a raster of the specified size with a numeric value and sends it into the workspace for processing. It is useful for creating a very large image with a user-specified width and height. |
| RasterReplacer | Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected raster format. |
| RasterRGBCreator | Creates a feature with a raster of the specified size with an RGB value and sends it into the workspace for processing. |
| RasterSelector |
Vectors and Rasters
| NumericRasterizer | Draws input point, line and polygon features onto a numeric raster filled with the background value. The Z coordinates of the input vector features are used to generate pixel values. Features without Z coordinates will be discarded. |
One resampled raster per input raster feature.
INVALID_RASTER_NO_BANDS
INVALID_PARAMETER_NUMBER_OF_ROWS
| Size Specification |
Select a method for specifying output raster size. Options include:
| Number of Columns (cells) | If Size Specification is RowsColumns, specify the desired raster width in cells (pixels). | ||||||
| Number of Rows (cells) | If Size Specification is RowsColumns, specify the desired raster height in cells (pixels). | ||||||
| X Cell Spacing | If Size Specification is CellSize, specify the desired cell (pixel) width in ground units. | ||||||
| Y Cell Spacing | If Size Specification is CellSize, specify the desired cell (pixel) height in ground units. | ||||||
| Percentage |
If Size Specification is Percentage, specify the desired percentage. This number must be greater than 0, and may be greater than or less than 100. 100 is equal to the input size. |
| Interpolation Type |
Cell values are interpolated to produce various raster sizes and resolutions. Choose a method:
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the RasterResampler on the FME Community.
