RasterSingularCellValueCalculator
Performs basic arithmetic operations on the cell values of a raster against a numeric value.
- Recalculating raster cell values by processing them individually against a numeric value
The RasterSingularCellValueCalculator receives raster features, and evaluates a defined arithmetic expression on the band value(s) of each cell.
The expression is composed of the cell value, an Operation, and a single numeric value (which may also be an attribute or expression). Available operations are addition, subtraction, multiplication, and division.
Particularly useful for operations where the order matters (subtraction and division), the Operand Order specifies whether the raster value or the numeric value is considered first.
The new values are output on the same band they were calculated from. Preserve Interpretation determines whether or not the band is converted to a different type on output - for example, the division of two integers may produce a floating point decimal result, converting the output band to interpretation type real64.
This transformer supports raster band selection. The RasterSelector can be used to modify the selection. Palettes are not supported.
In this example, we will convert the elevation values on a DEM dataset. The values are stored in Band 0, in meters, and we want them to be measured in feet. Note that the interpretation type is int32, and the values are integers.
The DEM is routed into a RasterSingularCellValueCalculator.
In the parameters dialog, we choose to multiply (Operation *) by the fixed number 3.28084 (feet per meter). Preserve Interpretation is set to No (though we will look at both kinds of results in this example). The Operand Order is not relevant to multiplication.
The output raster contains the new calculated values. Note that the results are now floating point decimal numbers, and the interpretation type of Band 0 is now real64.
If we set Preserve Interpretation to Yes, the new values will be converted to integers, and the interpretation type remains int32.
- This transformer performs calculations between one raster cell and a numeric value (Cell 1 <operator> Numeric Value). To perform calculations between two rasters (Cell 1 <operator> Cell 2), use the RasterCellValueCalculator.
- For more complex calculations, including multiple operators, consider using the RasterExpressionEvaluator.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterCellOriginSetter | Sets the raster's cell origin. |
| RasterConvolver |
| RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering the extents of the raster. |
| RasterGCPExtractor | Extracts the coordinate system and the Ground Control Points (GCP) from the raster feature and exposes them as attributes. |
| RasterGCPSetter | Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate. |
| RasterGeoreferencer | Georeferences a raster using the specified parameters. |
| RasterHillshader | Generates a shaded relief effect, useful for visualizing terrain. |
Alters the underlying interpretation of the bands of the raster geometry on the input features, using the specified conversion options. For example, an input raster feature with three bands of interpretation (UInt16, Gray8, and Real64) could be converted to a raster feature with three bands of interpretation (Red8, Green8, and Blue8) or four bands of interpretation (Red16, Green16, Blue16, and Alpha16) in a single operation. |
| RasterRotationApplier |
Applies the raster rotation angle on the input raster properties to the rest of the raster properties and data values. The expected input is a raster with a non-zero rotation angle and the expected output is a rotated raster with a rotation angle of 0.0. It is expected that the input raster properties will be modified to conform the output raster properties for a raster rotated by the given angle. Applying a rotation angle is primarily done for compatibility with other processing and writers that cannot handle a rotation angle. |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterCheckpointer | Sets a checkpoint in the raster processing which forces previous processing to occur immediately. Once complete, it saves the current state to disk. |
| RasterConsumer | Requests the tile(s) from the raster geometry but no actual operations are performed on the tile(s). |
| RasterExtractor | Serializes the geometry of the feature into the Blob Attribute based on the selected writer format. |
| RasterNumericCreator | Creates a feature with a raster of the specified size with a numeric value and sends it into the workspace for processing. It is useful for creating a very large image with a user-specified width and height. |
| RasterReplacer | Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected raster format. |
| RasterRGBCreator | Creates a feature with a raster of the specified size with an RGB value and sends it into the workspace for processing. |
| RasterSelector |
Vectors and Rasters
| NumericRasterizer | Draws input point, line and polygon features onto a numeric raster filled with the background value. The Z coordinates of the input vector features are used to generate pixel values. Features without Z coordinates will be discarded. |
Raster features to perform calculations on. Palettes are not supported.
Raster features with calculated values according to parameter selections, stored in the same band they were provided in.
INVALID_RASTER_NO_BANDS
INVALID_RASTER_MISSING_BAND
INVALID_FEATURE_MISSING_ATTRIBUTES
EXTRA_RASTER_HAS_PALETTE
| Operation |
The operation to perform. Choices include: + Add - Subtract * Multiply / Divide |
| Numeric Value |
Specify the numeric value portion of the arithmetic operation. The value can be specified either as a constant, an attribute, user parameter, or an expression. |
| Operand Order |
The order of the operands. This parameter only impacts non-commutative operations (subtraction, division), where the order affects the calculated value. Choices include:
| Preserve Interpretation |
Yes: Each output band will have the same interpretation as the corresponding input band. No: Interpretation of each output band will be automatically determined. Note that when converting between different data types, a Bounded Cast is used. When a calculated value does not fit in the specified destination interpretation, the corresponding destination value will either be set to the minimum or maximum value possible in the destination data type. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the RasterSingularCellValueCalculator on the FME Community.
