FME Transformers: 2024.1
RasterSlopeCalculator
Calculates the slope (maximum rate of change in z) for each cell of a raster.
- Calculating slope on elevation rasters
- Calculating the rate of change on raster band values
The RasterSlopeCalculator receives raster features, and calculates the slope for each cell.
Slope may be measured in either Degrees (0 to 90), or Percent Rise (0 to infinity). The calculation is done based on the values of surrounding cells (using a 3 cell x 3 cell window), and a choice of algorithms is available. Cells without data (Nodata) may be interpolated for calculation purposes.
Slope values are output on the same band they were calculated from, and the band is converted to Real64.
For multi-band rasters, each band is processed separately, with slope values calculated for each band on each cell. To restrict operation to specific band(s), use a RasterSelector prior to the RasterSlopeCalculator.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
Z Factor, Scaling and Units
Input rasters’ horizontal (x and y) units are expected to be the same as vertical (z) units.
If this is not the case - for example, if the horizontal units are in meters with elevation (z) in feet (or any other similar unit type mismatch), you may apply a scale factor (also known as Z Factor) with the Scaler transformer prior to using a RasterSlopeCalculator.
In this example (ground units are meters, elevations are feet), the scale factor to use is 0.3048 - the number of meters in one foot.
If the ground units are lat/long, the appropriate scale factor will vary greatly between the equator and the poles. In this case, consider reprojecting the input raster with a Reprojector, to an appropriate coordinate system with ground units matching the vertical (z) units.
In this example we will perform a slope calculation on a Digital Elevation Model. The source data ranges in elevation from sea level (0) to around 1500 meters, in a mountainous area. Note that elevation is stored in Band 0, as an integer.
The DEM is routed first into a Reprojector, where it is converted to UTM83-10, an appropriate local coordinate system with ground units in meters, matching the elevation value units. Then it is routed into a RasterSlopeCalculator.
In the parameters dialog, we select an Output Measurement of Degrees, and use the Horn algorithm. Interpolate Nodata is set to Yes.
The output raster feature has new Band 0 values - the calculated slope - and the band has been converted to a floating-point decimal interpretation type (real64).
Note the shape of the output raster compared to the original DEM data - a result of the reprojection.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with cells to calculate slope values on. Horizontal (x and y) units should be the same as vertical (z) units.
Raster features with calculated slope values, stored in the same band they were provided in, converted to interpretation type real64.
INVALID_RASTER_CANNOT_CALCULATE_SLOPE
Output Measurement |
Select the measurement units of the output slope data. Degrees: Slope will be calculated in degrees. Values will range from 0 (flat) to 90 (vertical). Percent Rise: Slope will be calculated as percent rise. Values will range from 0 (flat) to infinity (vertical). A flat surface will have a slope of 0 percent, a 45 degree surface will have a slope of 100 percent, and as the surface becomes more vertical the slope gets progressively larger. |
Interpolate Nodata |
Calculate values at raster edges and near Nodata values. No: When any pixel in the 3x3 window used to calculate the slope value is equal to Nodata, the output pixel will also be set to Nodata. If the input band does not have a Nodata value, the output band Nodata value will be set to -1. There will be a one pixel border around the edge of the raster set to the Nodata value. Yes: Values around the edge and near Nodata values will be estimated by interpolating missing values. Note that holes will not be filled in - cells that are Nodata in the input raster will remain Nodata in the output. |
Algorithm |
The algorithm used to calculate the slope. Some analyses have suggested that Horn's formula is better suited to rougher terrain, whereas Zevenbergen & Thorne's formula is better for smooth terrain. |
Search for all results about the RasterSlopeCalculator on the FME Community.
