FME Transformers: 2024.1
Scaler
Scales x, y, and/or z coordinate values to resize geometry.
Scaling z values for emphasis or de-emphasis
Scaling z values when vertical and horizontal units are mismatched
Georeferencing
Sizing objects or labels
Mirroring objects
Changing units
The Scaler receives features with any type of geometry and applies a multiplier to their coordinates, resizing the features relative to either their center or the origin of their coordinate system.
X, y and/or z coordinates are multiplied by the provided X, Y, and Z Scale Factors. A scale factor of one (1) implies no change to a coordinate.
The origin for scaling may be either 0,0 in the feature’s own coordinate system, or the center of the feature itself.
When using the 0,0 origin, if the object being scaled is not on or near the 0,0 point of the coordinate system (as is usually the case with georeferenced data), using the Scaler will also introduce a shift.
When using the Center Point origin, each individual feature will be scaled around its own center, not the center of the dataset’s extents.
Additional parameters are provided for type-specific scaling, including text, raster, and point cloud. This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
In this example, we have a set of park polygons, and want to scale them down.
The features are routed into a Scaler.
In the parameters dialog, the X and Y Scale Factors are set to 0.5. The Scale Origin chosen is Center Point.
The output features are half the size of the originals, and have been scaled around each feature’s center point.
- The Aggregator and Deaggregator may be useful for scaling around a dataset’s center.
- Reprojecting to a local coordinate system may also be useful - see the CommonLocalReprojector and Reprojector (to local coordinate systems).
Features with geometry to be scaled.
Features resized according to parameter selections.
Features that cannot be scaled will be output via this port. Rejected features will receive an explanatory fme_rejection_code attribute.
X Scale Factor |
Provide a multiplier for the feature’s x coordinates. Values may be entered directly or provided via an attribute, expression, user parameters, or conditional value. |
Y Scale Factor |
Provide a multiplier for the feature’s y coordinates. Values may be entered directly or provided via an attribute, expression, user parameters, or conditional value. |
Z Scale Factor |
Provide a multiplier for the feature’s z coordinates. Values may be entered directly or provided via an attribute, expression, user parameters, or conditional value. This parameter has no effect on two-dimensional vector features. On rasters, the multiplier is applied to the cell values of all selected bands. |
Scale Origin |
Select a scaling direction. Coordinates may be scaled relative to:
Text Scaling |
Select a method for scaling text features:
Note that text location is a point, and scaling a point from its own center will have no effect on position. |
Raster Scaling |
Select a method for scaling rasters:
Use this table to scale point cloud components other than x, y, and z.
Component |
Specify the component to scale. |
Scale Factor |
Provide a multiplier for the component. Note that more complex component value manipulations may be done with the PointCloudExpressionEvaluator. |
Search for all results about the Scaler on the FME Community.
