FME Transformers: 2024.1
RasterBandKeeper
Removes all unselected bands from a raster feature.
- Removing raster bands to meet processing or format requirements.
The RasterBandKeeper receives raster features and removes any unselected bands.
If all bands are selected, the raster will remain unchanged.
On reading, raster features by default have all bands currently selected. The selection may be changed by using the RasterSelector.
In this example, we will keep only the red band of an RGB orthophoto, removing the blue and green bands.
Note that the original raster feature has three bands, and the order of the bands is red, green, blue. They are numbered, starting with 0. We only want Band 0 - the red band.
The raster is routed first into a RasterSelector, and then into the RasterBandKeeper.
In the RasterSelector's parameters dialog, we alter the current selection (which is all bands selected). The Selection Mode is Band and Palette List, and the list 0 selects only the red band.
The RasterBandKeeper has no parameters to be configured.
The output raster feature contains only one band - Band 0, Red.
- The RasterBandKeeper and RasterBandRemover perform similar functions. The RasterBandKeeper is more useful when removing a proportionately large number of bands, whereas the RasterBandRemover is more useful when removing a small number of bands.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with any unselected bands removed.
INVALID_RASTER_NO_BANDS
Search for all results about the RasterBandKeeper on the FME Community.
