FME Transformers: 2024.1
RasterBandPropertyExtractor
Extracts the band and palette properties of a raster feature and adds them to a list attribute.
- Extracting band and palette information from raster features
The RasterBandPropertyExtractor receives raster features, and extracts any existing band and palette properties. The results are added to a new list attribute (because a raster may have multiple bands), and output with the original feature.
The transformer has no parameters.
Property attributes include:
_band{}.band_name
_band{}.band_interpretation
_band{}.band_bit_depth
_band{}.band_interleaving
_band{}.band_num_tile_rows
_band{}.band_num_tile_columns
_band{}.band_nodata
_band{}.band_num_palettes
_band{}.palette{}.palette_name
_band{}.palette{}.palette_key_interpretation
_band{}.palette{}.palette_value_interpretation
_band{}.palette{}.palette_bit_depth
Wherever "{}" appears, there will be one instance of the attribute for each band or palette. The first will appear with {0}, the second with {1}, and so on.
If a raster band has no palettes, _band{}.band_num_palettes will be zero (0), and no further palette attributes will be added.
In this example, we will extract the band properties on an RGB orthoimage. Note that the source raster feature has a number of attributes, and 3 bands.
The raster is routed into a RasterBandPropertyExtractor.
There are no parameter settings in this transformer. The raster is output, with new list attributes added containing properties for each band.
- This transformer extracts only band and palette properties. To extract raster geometry properties, such as the number of rows and columns, use the RasterPropertyExtractor.
- List attributes are not accessible from the output schema in FME Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. See About List Attributes for more information on using lists.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
This transformer accepts only raster features. Palettes are supported.
Raster features with list attributes containing band and palette properties.
INVALID_RASTER_NO_BANDS
| Aliases | RasterBandPropertiesExtractor |
Search for all results about the RasterBandPropertyExtractor on the FME Community.
