FME Transformers: 2024.1
RasterCellCoercer
Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes.
- Converting a raster to a vector grid of polygons
- Converting a raster to regularly spaced points, either 2D or 3D
- Creating an elevation grid
- Preparing raster data for vector-based analysis
The RasterCellCoercer accepts raster input features. Depending on the choice of Output Cell Geometry - points or polygons - either a point is created at each cell origin, or a polygon is traced around the boundary of each cell.
Band values are extracted from each cell, and may be handled as either Attributes or Z Values.
If values are extracted as Attributes, they are added to a new list attribute on the output features, with one list item per band. If they are extracted as Z Values, they are assigned to the z coordinate of the output features, and they are output as 3D.
Multi-band rasters: If Z Values is used with a multi-band raster, duplicate geometry will be created for each band (which can greatly increase output size and processing time). Extracting values as Z Values is typically most appropriate for single-band numeric rasters or DEMs. If Attributes is chosen on a multi-band raster, the band values (usually representing red, green, blue, and possibly alpha values, in a range from 0 to 255) are added as list items. Color is not assigned to the output features, but may be extracted from this list attribute and assigned using a FeatureColorSetter.
Nodata values may be kept or discarded.
Input raster attributes may optionally be kept, including the Raster ID, Band ID, and source column and row position. As these options may increase processing time, by default they are not added.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
When Extract Band Values is set to Z Values, each selected band must not contain a palette.
In this example, we will convert a DEM raster to points. The source dataset contains elevation as Band 0 values.
The raster is routed into a RasterCellCoercer.
In the parameters dialog, we select Output Cell Geometry as Points, and choose to Extract Band Values as Z Values.
Note that the Output Attribute Names do not have defaults, and so will not be created unless explicitly specified, as they can increase processing time substantially.
One point is output at the center of every cell, shown here with the original DEM displayed behind the point data. Note that the geometry is 3D, and the selected point has an elevation (z coordinate) of 46.
- This transformer can easily produce a very large number of vector features for each raster. For example a 1,000 x 1,000 RGBA image, fetched into the Z value, would produce four million point/polygon features. This can lead to the consumption of large amounts of system resources when carrying out transformation on the results, and result in writing very large output datasets.
- Very large processing tasks may benefit from using a PointCloudCombiner and PointCloudToPointCoercer as an alternate workflow (for point output only).
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Points or polygons with attributes as specified in the parameters.
INVALID_RASTER_NO_BANDS
MISSING_RASTER_NO_POINTS
RASTER_ALL_CELLS_NODATA
Output Cell Geometry |
Points: One point feature will be created for each of the raster's cells, positioned at the cell's origin. Polygons: Polygon features will be output, each one covering one of the raster's cells. |
Extract Band Values As |
Attributes: One feature will be output per cell in the raster. Band and palette values will be stored in attributes named _band{}.value and _band{}.palette{}.value. The output geometry will be 2D. Z Values: One feature will be output per band per cell in the raster. The output geometry will be 3D, where the z value is the band value. |
Extract Nodata Values |
Specifies whether point features will be output for Nodata cells in the raster. Yes: A feature will be output for each Nodata cell. No: Features will not be output for Nodata cells in the raster. Note that if No is selected , and all cells in the input raster are Nodata, the feature will be rejected. |
Preserve Attributes |
Specifies whether output geometry will retain the attributes from the input raster. Note that preserving attributes may add substantial processing time, as they are added to each output feature. |
Raster ID |
If specified, the name of the new attribute to contain an ID value corresponding to the original raster. |
Band ID |
If specified, the name of the new attribute to contain an ID value corresponding to the original band. Available when Extract Band Values As is set to Z Values. |
Column |
If specified, the name of the new attribute to contain the column position of the originating cell. Row 0, Column 0 corresponds to the upper-left corner. |
Row |
If specified, the name of the new attribute to contain the row position of the originating cell. Row 0, Column 0 corresponds to the upper-left corner. |
| Aliases | GridPointExtractor, RasterPointExtractor, RasterToPointCoercer |
| History | This transformer was previously known as the RasterToPointCoercer, RasterPointExtractor, or GridPointExtractor. |
Search for all results about the RasterCellCoercer on the FME Community.
