FME Transformers: 2024.1
RasterGCPExtractor
Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes.
- Extracting GCP raster properties to an attribute for use elsewhere in a workspace.
The RasterGCPExtractor receives raster features and extracts any Ground Control Points (GCPs) that exist as a raster property on the input feature. The following attributes are added to the output features:
_gcp_coordsys |
The GCP coordinate system. |
_gcp_value |
All existing GCPs, as a string. Each GCP has five components, separated by spaces: Column Row X-Coordinate Y-Coordinate Z-Coordinate For example: 1442 6863 483000 5456000 0 Multiple GCPs are combined into one string, separated by semicolons: 1442 6863 483000 5456000 0;1415 1143 483000 5468000 0;4754 1120 490000 5468000 0 |
The GCPs are not removed from the raster properties, and so exist as both properties and attributes on the output features.
In this example, we will extract the GCP coordinate system and values from a GeoTIFF raster.
Note that the source raster has GCPs stored as raster properties.
The raster is routed into a RasterGCPExtractor.
There are no parameters to configure.
The output raster feature has new attributes containing the GCP Coordinate System, and the GCP points as a string. The original GCP raster properties remain intact.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with GCP point values and coordinate system added as attributes.
Search for all results about the RasterGCPExtractor on the FME Community.
Contains information licensed under the Open Government Licence – Canada.
