FME Transformers: 2024.1
RasterCellValueReplacer
Replaces ranges of band values in a raster with single values.
- Classifying cell value ranges
- Adjusting image threshold
The RasterCellValueReplacer receives raster features. Each band value of each cell is compared to a defined set of numeric ranges, and values that match a range definition are replaced with a new, single defined value.
Ranges are defined in a Range Table, using From and To parameters, which may be combined in a variety of ways. If both parameters are defined, both are applied. These examples assume that the band values are integers.
Example |
From (>=) |
To (<=) |
Find values from 10 to 20 , inclusive |
10 |
20 |
Find the single value 45 |
45 |
45 |
Everything except the value 45 |
46 |
44 |
Find values less than 100 |
<blank> |
99 |
Find values of 50 or greater |
50 |
<blank> |
Find two distinct ranges at the upper and lower limits, values 50 and below, and values more than 99 (everything outside a range) |
99 |
50 |
Replace all values |
0 |
<blank> |
The new value may be defined as a single value, or as an expression.
For multi-band rasters, each band is processed identically on every cell, comparing the individual band values to the defined range(s). For example, if the range is <= 100, with a replacement value of 25, an RGB value of 14,87,192 becomes 25,25,192. To restrict operation to specific band(s), use a RasterSelector prior to the RasterCellValueReplacer.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
In this example, we will identify the range of elevation values less than 15 meters, and apply a single value (zero) to all cells that fall within that range, simulating a 15 meter sea level rise. The source data is a DEM in GeoTIFF format. Elevation is stored as the Band 0 value.
The DEM is routed into a RasterCellValueReplacer.
In the parameters dialog, we define a range of values less than or equal to 15. The new value is 0.
A raster feature is output, and all cells with elevations that fell within the range now have an elevation value of 0.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster feature(s) containing cells with values to be replaced.
Raster features with cell values replaced according to parameter selections.
INVALID_RASTER_NO_BANDS
From (>=) |
Specifies a range bounded by a minimum value, where all values greater than or equal to the supplied value will be replaced by the replacement value. |
To (<=) |
Specifies a range bounded by a maximum value, where all values less than or equal to the supplied value will be replaced by the replacement value. |
New Value |
Specifies the new value that will replace the specified range. Expressions, conditional values, and user parameters may be used. |
Replace Nodata |
Specifies whether Nodata values will be replaced. If set to Yes, Nodata values will be replaced just as any other values. If set to No, then Nodata values will not be replaced, even if they fall within the specified bounds. |
Search for all results about the RasterCellValueReplacer on the FME Community.
