FME Transformers: 2024.1
RasterExtractor
Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats.
- Storing rasters in databases that do not support specific raster types but do support Blobs.
- Storing a raster as an attribute of a feature, such as attaching images to vector features.
The RasterExtractor receives raster features and puts a copy of the raster geometry into an attribute, as a Blob - a Binary Large OBject.
The Blob content may be encoded as a variety of common raster formats. The name of the chosen format will also be recorded in an attribute for reference when decoding.
There are no parameters in the transformer to control how the raster is formatted, and encoding is done based on default settings for the chosen format. If necessary, format-specific settings may be overwritten by setting format attributes on the raster feature, prior using the RasterExtractor. For example, if encoding to JPEG, the compression level could be set via the jpeg_compression_level format attribute. Consult the appropriate format’s Writer documentation for a complete list of available attributes.
In this example, we will prepare and write a raster to a Microsoft SQL Server Non-Spatial database, which does not support geometry of any form as an attribute type.
The raster feature is routed into a RasterExtractor, and then on to a Microsoft SQL Server Non-Spatial Writer.
In the parameters dialog, Format is set to GeoTiff, and the Format Name and Blob attributes are left with the default names applied.
Examining the output from the RasterExtractor in the FME Data Inspector, note that the feature has two new attributes - _rasterBlob, containing the encoded raster, and _rasterFormatName, containing the name (GeoTIFF) of the chosen encoding.
In the writer parameters, User Attributes, the Type of _rasterBlob is adjusted to Image, which is a binary field that supports larger values than varbinary, ensuring the data will not be truncated. (Note that the appropriate data type may vary between database formats.)
- This transformer may be used for writing raster data to a database field. Note that when writing the Raster Blob Attribute, you may need to adjust the attribute type to an unbounded data type to avoid truncation of the data. Choose an appropriate attribute type depending on the destination format (for example, an appropriate attribute type for SQL Server is 'image').
- The RasterReplacer may be used to perform the reverse operation and convert the encoded blob back to the original raster geometry.
- Different encoding formats may carry through different information. For example, GeoTIFF preserves coordinate system and extents, whereas PNG does not.
- To carry out a similar operation on vector data, use the GeometryExtractor transformer. For point cloud data, use the PointCloudExtractor.
- To remove the original geometry after using a RasterExtractor (leaving only the Blob attribute version), use a GeometryRemover.
- The AttributeFileWriter transformer can be used to write the Raster Blob Attribute directly to a file.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with their geometry also encoded as an attribute as specified.
INVALID_FEATURE_CANNOT_WRITE
Format |
The raster format used to encode the blob. Choices include:
Format Name |
Name the attribute to contain the selected Format name. |
Blob |
Name the attribute to contain the encoded Blob. |
Search for all results about the RasterExtractor on the FME Community.
