FME Transformers: 2024.1
RasterBandRemover
Removes any selected bands from a raster feature.
- Removing raster bands to meet processing or format requirements.
The RasterBandRemover receives raster features and removes any selected bands.
On reading, raster features by default have all bands currently selected. The selection may be changed by using the RasterSelector.
In this example, we will remove the blue and green bands from an orthophoto, leaving the red band intact.
Note that the original raster feature has three bands, and the order of the bands is red, green, blue. They are numbered, starting with 0. We only want Band 0 - the red band.
The raster is routed first into a RasterSelector , and then into the RasterBandRemover.
In the RasterSelector parameters dialog, we alter the current selection (which is all bands selected, as the feature has just exited its reader). The Selection Mode is Band and Palette List, and the list 1;2 selects only the green and blue bands.
The RasterBandRemover has no parameters to be configured.
The output raster feature contains only one band - Band 0, Red.
- The RasterBandKeeper and RasterBandRemover perform similar functions. The RasterBandKeeper is more useful when removing a proportionately large number of bands, whereas the RasterBandRemover is more useful when removing a small number of bands.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with any selected bands removed.
INVALID_RASTER_NO_BANDS
Search for all results about the RasterBandRemover on the FME Community.
