FME Transformers: 2024.1
RasterBandInterpretationCoercer
Alters the interpretation type of individual raster bands, converting cell values if necessary.
- Changing individual raster band interpretation to meet processing or format requirements
The RasterBandInterpretationCoercer receives raster features and converts all or selected bands to one chosen Destination Interpretation Type.
Options are available to control the manner in which cell values are converted, handling color to color, numeric to color, color to numeric, numeric to numeric, and floating-point to integer conversions.
Band names, if they exist, are retained.
If bands selected for conversion contain palettes, the destination interpretation is restricted to UInt8, UInt16 or UInt32.
To select specific bands, use the RasterSelector prior to the RasterBandInterpretationCoercer.
In this example, we will convert a single-band numeric raster to gray. The source raster is a GeoTIFF, with cell values ranging from 0 to 10, representing different land zoning. Note that the raster contains one band, and the interpretation type is INT8 - an 8-bit integer.
The FME Data Inspector knows the value range, and displays the cells as shades of gray, where 0 is black and 10 is white.
However, viewing the raster in another image viewer shows a nearly solid black image, because the values (maximum 10), when interpreted against a range of 0 to 255, are close to zero.
In order to use the raster for presentation purposes, it needs to be converted to a proper gray scale.
The raster is routed into a RasterBandInterpretationCoercer.
In the parameters dialog, we set the Destination Interpretation Type to Gray8. Three Conversion Options are enabled (as the transformer does not know what type of band will be received).
The important one for this translation is Convert from Numeric to Color. We choose Scale by data values, which will take the source range (0 to 10), and scale the values according to the destination type range (0 to 255).
The output raster feature contains a single band, and the Interpretation Type is now GRAY8. Note the cell value selected, previously 8, is now 204.
- The RasterInterpretationCoercer performs similar operations on the raster as a whole, such as converting 4 bands directly to RGBA.
- The RasterPaletteInterpretationCoercer performs similar conversions on palettes.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with bands modified as specified.
Destination Interpretation Type |
Select the destination interpretation along with the bit depth. Different interpretations allow for different conversion options to be used. |
Convert from Color to Color Convert from Numeric to Color Convert from Color to Numeric Convert from Numeric to Numeric |
Select the action to undertake when the given conversion between different types occurs.
Convert from Float to Integer |
Specifies the action to perform when converting from a floating-point value to an integer.
* Note: Cast and Bounded Cast use C-style casts.
| History | This transformer replaces the RasterDataTypeCoercer and RasterColorModelCoercer transformers. |
Search for all results about the RasterBandInterpretationCoercer on the FME Community.
