FME Transformers: 2024.1
RasterPaletteExtractor
Creates a string representation of an existing palette on a raster and saves it to an attribute.
- Extracting a palette to be saved to an external file
- Extracting a palette to apply to other rasters or for use elsewhere in a workspace
The RasterPaletteExtractor receives raster features and copies the palette information to a string attribute. Only one palette may be extracted at a time.
This transformer supports raster band and palette selection. Exactly one palette must be selected on each input raster feature. The RasterSelector can be used to modify selection.
This transformer may be used in combination with the AttributeFileWriter to write a palette to a file.
Format of Palette Attributes
The general format of a palette attribute is as follows:
Format |
RGB Example |
String Example |
<value interpretation> [<string length>] |
RGB24 |
STRING 10 |
The first line of the palette must contain the value interpretation. Valid values for the value interpretation are:
- RGB24
- RGBA32
- RGB48
- RGBA64
- GRAY8
- GRAY16
- STRING
RGBA and RGB palette values consist of comma-delimited strings of integers between 0 and the maximum value of the data type. For example, a valid RGBA32 value would be 64,128,255,255, and a valid RGB48 value would be 16384,32768,65535.
When an interpretation of STRING is specified, the first line may optionally specify the maximum string length of the palette values. This value must be a positive integer. If no string length is explicitly specified, a default of 32 will be assumed.
STRING palette values may consist of any arbitrary text, except for the newline character.
GRAY palette values consist of a single integer between 0 and the maximum value of the data type.
All lines after the first are key-value pairs. Palette keys must be organized in ascending order, but they are not required to be contiguous - that is, not all numbers in the series must be present. All absent palette keys look up to 0 or an equivalent value, such as 0,0,0 for RGB or an empty string for string palettes.
In this example, we will extract a palette and write it to a text file. Note that the source raster has one palette, and so a RasterSelector is not needed.
Two steps are required:
- Extract the palette to an attribute.
- Write the contents of that attribute to a file.
The raster is first routed into a RasterPaletteExtractor. In the parameters dialog, thePalette attribute is given the name _palette.
As the raster feature exits this transformer, the palette has been added to it in string attribute form. The original palette remains intact.
The feature is now routed into an AttributeFileWriter. In the parameters dialog, Source Attribute is set to _palette, and a path and file name are designated for the text file to be written.
The resulting text file contains the palette.
- To add an extracted palette to another raster, use the RasterPaletteAdder.
- To generate a palette from the existing cell values in a raster, use the RasterPaletteGenerator.
- To remove a palette from a raster, use the RasterPaletteRemover.
- To replace cell values with palette values, use the RasterPaletteResolver.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
This transformer accepts only raster features. The input raster must have one palette selected.
Raster features with the selected paletted added to the specified attribute.
INVALID_FEATURE_CANNOT_WRITE
Palette |
Name the attribute to contain the palette. |
Search for all results about the RasterPaletteExtractor on the FME Community.
