FME Transformers: 2024.1
RasterSingularCellValueCalculator
Performs basic arithmetic operations on the cell values of a raster against a numeric value.
- Recalculating raster cell values by processing them individually against a numeric value
The RasterSingularCellValueCalculator receives raster features, and evaluates a defined arithmetic expression on the band value(s) of each cell.
The expression is composed of the cell value, an Operation, and a single numeric value (which may also be an attribute or expression). Available operations are addition, subtraction, multiplication, and division.
Particularly useful for operations where the order matters (subtraction and division), the Operand Order specifies whether the raster value or the numeric value is considered first.
The new values are output on the same band they were calculated from. Preserve Interpretation determines whether or not the band is converted to a different type on output - for example, the division of two integers may produce a floating-point decimal result, converting the output band to interpretation type real64.
This transformer supports raster band selection. The RasterSelector can be used to modify the selection. Palettes are not supported.
In this example, we will convert the elevation values on a DEM dataset. The values are stored in Band 0, in meters, and we want them to be measured in feet. Note that the interpretation type is int32, and the values are integers.
The DEM is routed into a RasterSingularCellValueCalculator.
In the parameters dialog, we choose to multiply (Operation *) by the fixed number 3.28084 (feet per meter). Preserve Interpretation is set to No (though we will look at both kinds of results in this example). The Operand Order is not relevant to multiplication.
The output raster contains the new calculated values. Note that the results are now floating-point decimal numbers, and the interpretation type of Band 0 is now real64.
If we set Preserve Interpretation to Yes, the new values will be converted to integers, and the interpretation type remains int32.
- This transformer performs calculations between one raster cell and a numeric value (Cell 1 <operator> Numeric Value). To perform calculations between two rasters (Cell 1 <operator> Cell 2), use the RasterCellValueCalculator.
- For more complex calculations, including multiple operators, consider using the RasterExpressionEvaluator.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features to perform calculations on. Palettes are not supported.
Raster features with calculated values according to parameter selections, stored in the same band they were provided in.
INVALID_RASTER_NO_BANDS
INVALID_RASTER_MISSING_BAND
INVALID_FEATURE_MISSING_ATTRIBUTES
EXTRA_RASTER_HAS_PALETTE
Operation |
The operation to perform. Choices include: + Add - Subtract * Multiply / Divide |
Numeric Value |
Specify the numeric value portion of the arithmetic operation. The value can be specified either as a constant, an attribute, user parameter, or an expression. |
Operand Order |
The order of the operands. This parameter only impacts non-commutative operations (subtraction, division), where the order affects the calculated value. Choices include:
Preserve Interpretation |
Yes: Each output band will have the same interpretation as the corresponding input band. No: Interpretation of each output band will be automatically determined. Note that when converting between different data types, a Bounded Cast is used. When a calculated value does not fit in the specified destination interpretation, the corresponding destination value will either be set to the minimum or maximum value possible in the destination data type. |
Search for all results about the RasterSingularCellValueCalculator on the FME Community.
