FME Transformers: 2025.2
Categories
Point Clouds
Related Transformers
GeometryCoercer
PointCloudToPointCoercer
PointCloudCombiner
Combines features into a single point cloud. Point cloud and non-point cloud geometries are supported.
Jump to Configuration
  • Combining multiple point clouds into a single feature
  • Converting non-point cloud features to a point cloud in order to process them against point cloud features
  • Converting non-point cloud geometry to a point cloud to take advantage of processing efficiency gains
The PointCloudCombiner receives one or more features and combines them into a single point cloud output feature, converting geometry to point clouds if necessary.
When combining multiple input features, all features must be in the same coordinate system, regardless of geometry type.
Attributes and measures may optionally be preserved as point cloud components.
The various input geometry types are each handled differently.
Point Clouds
Input point cloud features are simply combined with no further modifications. They may be combined with additional point clouds and/or any other input geometry type.
Vectors
Vectors are converted as follows:
  • Point and curve features are converted vertex for vertex - that is, each vertex in the vector geometry will produce a point in the point cloud.
  • Polygonal, donut, surface and solid features are converted into a grid of points lying inside the area on the 3D plane represented by the area’s calculated normal. The density of the grid may be adjusted with the Point Interval parameter.
Rasters
Rasters are converted as follows:
  • The x and y components are created from the cell ground coordinates, or columns and rows if the raster has no coordinate system.
  • The first selected numeric band will become the z component.
  • The first selected bands with red/green/blue/gray interpretations will become the color_red/color_green/color_blue components.
  • Additional selected bands will also be preserved. If the band has a name, the component name will be the band name. If the band has no name, the component name will be bandN, where N is the band index.
  • Nodata may optionally be extracted.
  • When combining multiple input features (regardless of format), they must be in the same coordinate system. The CoordinateSystemSetter and Reprojector transformers may be useful.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the PointCloudCombiner on the FME Community.
