• Workbench Basics
    • About FME Workbench
      • Welcome to FME Workbench
      • Copyright and Trademark Notices
      • About FME
      • FME Terminology
      • Download the Transformer Quick-Reference Guide
      • Support and Resources
    • Understanding Schema
    • Creating Workspaces
      • Using the Workspace Dialog
      • About Dynamic Workspaces
      • About Templates
      • Copying Between Workspaces
      • Copying Workspaces to Mapping Files
    • Running and Debugging Workspaces
      • About Data Inspection
      • About Feature Inspection
      • Temporarily Disabling Connections
      • Running a Batch Translation
      • Working with Command Files
      • Stopping a Translation
      • Viewing the Log
    • Organizing Workspaces
      • Arranging Objects on the Canvas
      • Using Annotations
      • Using Bookmarks
      • Hiding Connections
    • About the FME Data Inspector
      • Data Inspector Interface
      • Types of Datasets
      • Selecting a Dataset to View
      • Querying Features
    • User Interface Reference
      • Starting FME Workbench
      • FME Options
      • Menus, Tools and Options
      • Menu Commands and Shortcuts
      • Workbench Keyboard Shortcuts
      • Workbench Canvas
      • Workspace Navigator
      • Overview Window
      • Parameter Editor
      • History Window
      • Searching in Workspaces
      • Setting the Feature Count Display
      • Viewing Rejected Features
      • Window Management
  • Reading and Writing Data
    • Terminology
    • Dataset Types
    • Adding Readers
      • Quick Add
    • Merging Similar Datasets
    • Adding a Reader as a Resource
    • Adding Writers
      • Quick Add
    • Readers and Writers: Zip Files and URLs
      • Reading from a Zip File
      • Writing to a Zip File
      • Reading from a URL
    • Defining Destination Data Characteristics
    • Deriving Destination Schema from Schema Feature
    • Updating Readers and Writers
    • Performing Other Tasks with Readers and Writers
    • Feature Types and Attributes
      • Mapping Attributes from Reader to Writer
      • Managing Feature Types
      • Updating Feature Types
      • Feature Type and Attribute Menu Reference
      • Editing Reader Feature Types
      • Editing Writer Feature Types
      • Modifying Feature Types to Read
      • Merging Feature Types
      • Managing Feature Type Connections
      • Controlling Features with Format Attributes
      • Managing Attribute Connections
      • Adding and Copying Attributes
      • Editing Geodatabase Domains and Subtypes
    • Separating Output Data with Fanout
      • Setting Dataset Fanout
      • Setting Feature Type Fanout
    • Custom Formats
      • Creating a Custom Format
      • Using a Custom Format in a Workspace
      • Maintaining Custom Formats
      • Installing a Custom Format
      • Sharing a Custom Format
  • Transforming Data
    • Understanding Content Transformation
    • Adding, Connecting and Removing Transformers
      • Quick Add
      • Quick Connect
      • Drag-and-Insert
      • Using Junctions
      • Auto Connect to Destination Feature Types
      • Smart Delete
      • Temporarily Disabling Transformers
    • Property Menus (Transformers)
    • Working with Transformer Parameters
      • Transformer Parameter Menu Options
      • FME Parameters
      • FME Server Parameters
      • Arithmetic Editor
      • Text Editor
      • Regular Expression Editor
      • Transformer Parameter Defaults
      • Incomplete Transformers
    • Inserting Attributes to Transformer Outputs
    • Using a Series of Transformers
    • Controlling Transformer Flow at Runtime
    • Working with Transformer Versions
    • Locating Transformers
    • Download the Transformer Reference Guide
    • Custom Transformers
      • Creating Custom Transformers
      • Using Custom Transformers
      • Custom Transformer Parameters
      • Duplicating Custom Transformers
      • Working with Multiple Copies of Custom Transformers
      • Looping Custom Transformers
      • Exporting Custom Transformers
      • Embedding or Linking a Custom Transformer
      • Sharing Custom Transformers
      • Working with Multiple Versions of Custom Transformers
      • Installing Custom Transformers
      • Removing Custom Transformers
  • Other Workbench Tasks
    • Working with User Parameters
      • Creating and Modifying User Parameters
      • Creating a User Parameter Based on a Workspace Parameter
      • Sharing Values Between Parameters
      • Running a Workspace with Published Parameters
    • About List Attributes
      • Understanding List Attributes
      • How List Attributes Are Created
      • Exposing List Attributes
      • Operating on List Attributes
    • Understanding FME Geometry
      • Geometry Concepts
      • FME Geometry Model
    • Working with Coordinate Systems
      • Key Concepts in Coordinate Systems and Mapping
      • How FME Identifies Coordinate Systems
      • Choosing from the Coordinate System Gallery
      • Reprojecting Data
      • Reverting to Original Coordinate Systems
      • Search Envelopes and Coordinate Systems
      • Custom Coordinate Systems
      • Projection Types
      • Defining New Ellipsoids
      • Predefined Units
      • Defining Custom Units
      • Quadrants
    • Working with FME Server
      • Publishing to FME Server
      • User and Role-based Transformations
      • Sharing Custom Formats, Transformers, Coordinate Systems
      • Republishing to FME Server
      • Publishing Templates to FME Server
      • Importing Custom Python Modules to FME Server
      • Downloading from FME Server
      • Viewing Connection Information
    • Working with Databases and Web Services
      • Using Database Connections
      • Using Web Connections
      • How FME Logs Database Information
      • Connecting to External Databases
      • Database Connection Issues
    • FME Administration Tasks
      • Extending Applications with the Integration Console
      • FME Files: Names and Locations
      • Daylight Savings Time
      • Adjusting Memory Resources
      • License Borrowing
  • All Files
    • Geometry Concepts
      • Nulls (IFMENull)
      • Points (IFMEPoint)
      • Text (IFMEText)
      • Curves (IFMECurve)
        • Segments (IFMESegment)
        • Paths (IFMEPath)
      • Areas (IFMEArea)
        • Simple Areas (IFMESimpleArea)
        • Donuts (IFMEDonut)
      • Surfaces (IFMESurface)
        • Simple Surfaces (IFMESimpleSurface)
        • Composite Surfaces (IFMECompositeSurface)
      • Solids (IFMESolid)
        • Simple Solids (IFMESimpleSolid)
        • Composite Solids (IFMECompositeSolid)
      • Rasters (IFMERaster)
      • Point Clouds (IFMEPointCloud)
      • Multis
      • Aggregates (IFMEAggregate)
      • Feature Tables (IFMEFeatureTable)
      • Geometry Definitions and Instances
      • Multiple Geometries
You are here: Other Workbench Tasks > Understanding FME Geometry > FME Geometry Model
FME Geometry Model
FME provides a comprehensive geometry model that includes everything from the simplest geometry to the most complex.
Click on a geometry class for more information.
