| AE |
Albers Equal Area
| AZMEA |
Lambert Azimuthal Equal Area
| AZMED |
Lambert Azimuth Equidistant
| AZMED-ELEV |
Lambert Azimuthal Equidistant, Elevated Ellipsoid
| BIPOLAR |
Bipolar Oblique Conformal Conic
| BONNE |
Bonne
| CASSINI |
Cassini
| ECKERT4 |
Eckert 4
| ECKERT6 |
Eckert 6
| EDCNC |
Equidistant Conic
| EDCYL |
Equidistant Cylindrical
| EDCYL-E |
Equidistant Cylindrical Projection (Ellipsoidal or Spherical)
| GAUSSK |
Gauss Kruger Projection, aka Gauss
| GEOCENTRIC_FME |
Geocentric
| GNOMONIC |
Gnomonic
| GOODE |
Good Homolosine
| HOM1UV |
Hotine Oblique Mercator – one point, unrectified
| HOM1XY |
Hotine Oblique Mercator, Alaska Variation
| HOM2UV |
Hotine Oblique Mercator – two points, unrectified
| HOM2XY |
Hotine Oblique Mercator – two points, rectified
| KROVAK |
Krovak Oblique Conformal Conic, Czechoslovkia
| KROVAK95 |
Krovak Oblique Conformal Conic, Czechoslovkia, 1995 Adjustment
| LL |
Latitude/Longitude
| LM |
Lambert Conformal Conic
| LM1SP |
Lambert Conformal Conic Projection, One Standard Parallel
| LMAF |
Lambert Conformal Conic (2SP) with Affine Post Process
| LMBLGN |
Lambert Conformal Conic Projection, Belgian Variation
| LM-MNDOT |
Lambert Conformal Conic, Minnesota DOT Variation
| LMTAN |
Lambert Tangential
| LM-WCCS |
Lambert Conformal Conic, Wisconsin County Variation
| MILLER |
Miller Cylindrical
| MODPC |
Modified Polyconic
| MOLLWEID |
Mollweide Projection
| MRCAT |
Mercator Cylindrical Projection with Standard Parallel (Traditional)
| MRCAT-PV |
Popular Visualisation Pseudo Mercator
| MRCATK |
Mercator Cylindrical Projection with Scale Reduction
| MSTERO |
Modified Stereographic
| NEACYL |
Normal Aspect Equal Area Cylindrical
| NERTH |
NonEarth
| NERTH-SRT |
NERTH-SRT
| NZEALAND |
New Zealand National Grid
| OBQCYL |
Oblique Cylindrical
| ORTHO |
Orthographic
| OSTERO |
Oblique Stereographic (International)
| OSTEROUS |
Oblique Stereographic (per Snyder USA)
| OSTN02 |
ETRF89 Referenced OSGB
| OSTN97 |
ETRF89 Referenced OSGB (ETRF89<-->OSGB via OSTN97)
| PCARREE |
Plate Carree / Simple Cylindrical
| PLYCN |
American Polyconic
| PSTERO |
Polar Stereographic Projection
| ROBINSON |
Robinson
| RSKEW |
Rectified
Skew Orthomorphic, Azimuth at Projection Center
| RSKEWC |
Rectified
Skew Orthomorphic, Origin and Azimuth at Center
| RSKEWO |
Rectified
Skew Orthomorphic, Skew Azimuth at Rectified Origin
| SINUS |
Sinusoidal
| SOTM |
South-Oriented Transverse Mercator
| SWISS |
Swiss Oblique Cylindrical Projection
| SYSTM34 |
Danish System 34, UTM + polynomials (pre-1999 vintage)
| SYSTM34-01 |
Danish System 34, UTM + polynomials (2001 vintage)
| SYSTM34-99 |
Danish System 34, UTM + polynomials (1999 vintage)
| TEACYL |
Transverse Aspect Equal Area Cylindrical
| TM |
Transverse Mercator
| TMAF |
Transverse Mercator (Gauss/Kruger) with Affine Post Process
| TM-MNDOT |
Transverse Mercator, Minnesota DOT Variation
| TM-SNYDER |
Transverse Mercator per J. P. Snyder
| TM-WCCS |
Transverse Mercator, Wisconsin County Variation
| TRMRKRG |
Transverse Mercator using Kruger Formulation
| UTM |
Universal Transverse Mercator System
| VDGRNTN |
Van Der Grinten
