You are here: Reference Manual > FME Server Core > Role-Based Access Control > Configurable Parameters for Active Directory Connections > SECURITY_AD_SERVER_AUTODETECT
Required. Enables or disables auto-detection of Active Directory servers.
When auto-detection is enabled, FME Server contacts the DNS server and requests the hostname of the Active Directory server. The configuration parameter SECURITY_AD_SERVER_DNS_RECORD_NAME can be used to fine-tune the auto-detection process.
When auto-detection is disabled, Active Directory servers must be specified through the configuration parameters SECURITY_AD_SERVER_COUNT, SECURITY_AD_SERVER_HOST, and SECURITY_AD_SERVER_PORT.
