FME Server Parameters
FME Server parameters reference FME Server system settings when a workspace is run from FME Server. These parameters may be useful when testing or debugging a workspace that is going to be run from FME Server.
FME Server parameters are listed in the table below:
| Parameter | Description |
| FME_DATA_REPOSITORY | Contains the name of the folder used by FME Server’s Web User Interface for temporarily uploading data. |
| FME_SECURITY_ROLES |
Contains the role of the FME Server user who is running the workspace. For example, Administrator and Author are two common roles. |
| FME_SECURITY_USER |
Contains the FME Server user name of the person who is running the workspace. |
| FME_ENGINE |
Contains the name of the FME Server Engine running the workspace. |
| FME_JOB_ID |
FME Server job identifier for the job that invokes this workspace. |
| FME_TOPIC |
Name of the FME Server Notification Service topic used to invoke this workspace. |
| FME_TOPIC_MESSAGE | The location of the FME Server Notification Service message. This parameter is set only in workspaces that are run from an FME Server workspace subscriber. For more information, see Workspace Subscriber in the FME Server documentation. |
| FME_SERVER_HOST |
The FME Server host name used to invoke this workspace. |
| FME_SERVER_PORT |
The FME Server port used to invoke this workspace. |
| FME_SERVER_WEB_URL |
The FME Server Application Server root URL used to invoke this workspace. |
| FME_SERVER_REQUEST_HEADERS |
The FME Server Web Service request header information, which includes the client IP of requests used to invoke this workspace. |
| FME_SERVER_REQUEST_URI |
The FME Server Web Service URI used to invoke this workspace. |
| FME_SERVER_REQUEST_METHOD | The HTTP request method used to invoke the workspace. This parameter is set only in workspaces that are run by the FME Server Data Streaming service. For more information, see Data Streaming Service in the FME Server documentation. |
| FME_SHAREDRESOURCE_TEMP | The name of the FME Server Resources folder for storing temporary files created by FME Server. |
| FME_SHAREDRESOURCE_DATA | The name of the FME Server Resources folder for storing data files that can be shared between workspaces. |
| FME_SERVER_DEST_DIR | The file path where the FME Server Data Download and Data Streaming services write output data. |
| FME_SERVER_REQUEST_PARAMETERS | The FME Server Web Services request query parameters. Includes query parameters passed as part of the URL, as well as query parameters sent through a POST request body of content type "application/x-www-form-urlencoded" and "multipart/form-data". |
See Also
