You are here: Spatial Analysis > Dissolver
Dissolver
Dissolves area features by removing common boundaries to create larger areas. Input attributes may be accumulated.
  • This transformer accepts two-dimensional polygonal features, including donuts. These polygonal features are broadly referred to as polygons.
  • Aggregate input will be deaggregated by the transformer. Attributes on the aggregate feature will be propagated to its parts.
Tip: If part-specific attributes, such as areas, need to be computed and preserved, please deaggregate before dissolving.
Because aggregates are deaggregated inside the Dissolver, it is possible that the number of output features will exceed the number of input features.
  • Dissolved polygons are formed when shared edges and interior edges between adjacent polygons are removed.
Output
Example
The example below shows areas before and after a Dissolver transformer was used.
Transformer Categories
Geometries
Spatial Analysis
Search FME Knowledge Center
Tags Keywords: aggregate aggregation "technology preview"
