You are here: Filters and Joins > ConvexityFilter
ConvexityFilter
Determines whether areas, surfaces, and solids are convex or concave. A polygon is simple when it is not self-intersecting and has a non-zero area. Simple polygons are convex if every internal angle is less than or equal to 180 degrees. All other polygons are considered concave.
If the geometry of the feature is polygon-based (such as a polygon, a donut, or a box) all of the geometry’s composing polygons are tested for convexity. Based on the results of this testing, the appropriate output port is determined.
There are no parameters for this transformer.
  • Lines and points are considered concave.
  • The test is limited by the precision of the geometry’s coordinates – be careful of “invisible” bends in lines, as shown here:
Example
This diagram shows both convex and concave examples.
FME Licensing Level
FME Professional Edition and above
Transformer Categories
Data Quality
Filters and Joins
Related Transformers
HullAccumulator
HullReplacer
Search FME Knowledge Center
Tags Keywords: convex concave "polygon based" "internal angle"
