You are here: Geometries > BoundingBoxReplacer
BoundingBoxReplacer
Replaces the geometry of the feature with either its two-dimensional bounding box or its two-dimensional minimum oriented bounding box.
If a feature’s bounding box has zero area, it will become a line or a point. If the feature was originally 3D, it will be set to 2D upon leaving, and the z values will be ignored and dropped.
Example
Related Transformers
  • To accumulate the bounding box of a number of features, use the BoundingBoxAccumulator.
  • To retrieve the bounds of a feature into attributes, use the BoundsExtractor.
  • To replace the geometry of a feature with a box whose values come from attributes, use the 2DBoxReplacer.
Transformer Categories
Geometries
Search FME Knowledge Center
Tags Keywords: MBR "minimum bounding rectangle" neatline "envelope oriented" "bounding box"
