You are here: Workflows > PythonCreator
PythonCreator
Creates features using the Python script supplied, and sends them into the workspace for processing. The Python script must be in the form of a Python class, with the code responsible for creating the features located in the close() method.
Features are created via the FME Objects Python API.
Example Class
The example below creates a random number of features, between 0 and 9.
import fmeobjects
import random
class FeatureCreator(object):
def __init__(self):
self.number = random.random()
def close(self):
for i in range(1, int(self.number*10)):
feature = fmeobjects.FMEFeature()
feature.setAttribute("feature_count", i)
self.pyoutput(feature)
Script Editing
A PythonCreator transformer can call scripts stored in the transformer itself or stored globally for the entire workspace:
  • To store a Python script with a specific PythonCreator transformer, use the “Python Script” property of the transformer.
  • To store a Python script globally, click the Advanced Workspace Parameter in the Navigator, and double-click Startup Python Script. Storing scripts globally has the advantage of keeping your Python logic centralized, which makes editing and maintenance easier. This is useful if you want to have multiple PythonCreator transformers throughout your workspace that use the same script. For more information, see Startup and Shutdown Python Scripts in the FME Workbench help.
If you are using extensive Python libraries that you do not want to store inside a workspace: to avoid duplication, you can access .py files on the file system using Python’s import command. In addition to the standard Python module locations, FME will also search the location of the workspace for an imported Python module.
Transformer Categories
Workflows
Dependencies
Specifying a Python Interpreter
An FME installation includes a Python version 2.7 and Python version 3.5 interpreter. The default Python interpreter used for Python processing is the Python 2.7 interpreter. The FME Objects Python API supports Python 2.7, Python 3.4, and Python 3.5.
The Python interpreter used by FME to execute Python scripts is controlled by the Python Compatibility workspace parameter and the Preferred Python Interpreter setting under Tools > FME Options > Translation.
Python Compatibility specifies the version of Python with which Python scripts are compatible. FME loads the Preferred Python Interpreter if it is compatible with the Python Compatibility. If not, FME loads an appropriate Python interpreter matching Python Compatibility.
For more information, see the FME Workbench help.
Installing Python Packages
If you would like to install a third-party package for use by Python in FME, see Installing Python Packages to FME Desktop in the FME Workbench help.
FME Licensing Level
Search FME Knowledge Center
